Results 1 to 10 of 14
Thread: Designs for slide in/out screen
    Oct 2003
    Toronto, Canada
    hey, just wondering if you guys can post what you have/seen or planning to do to make the enclosure for the screens and specifically, for being able to slide it in/out.
    So far i figured i can make the roller part fairly easily using some plexiglass, which will give me the horizontal movement for the screen. But now I'm stuck on the vertical part, just not sure what would be a good design for being able to angle the screen.
    Here is what i'm talking about:
    where the (-'s) are the rollers to provide the horizontal movement and the (||'s) represent the screen.
    Any help would be appreciated!
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    what about a hinge that runs the lengthe of the whole setup that tilts up 90 deg:
    ||||||||0---------
    0-----------
    where - is the rollers
    || in the first design is the screen,
    = is the hinge, with the joint being 0
    Oct 2003
    Toronto, Canada
    That is the most obvious solution, question that comes to my mind is how to lock the hinge securely and at the same time make it so it's easy to fold it down also.
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Oct 2003
    Toronto, Canada
    Anyone know any sources for a 90 degree lock hinge? Because that would solve all the problems on the spot!
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Constant Bitrate spectrrr's Avatar
    Jan 2004
    Dayton, OH / Cambridge, MA
    another hinge type option:
    I've taken old laptops apart before for parts. The hinge on the screen is just a little thing that looks kinda likd this: __==__ (where __ is a flat part with screw holes and == is the round hinge).
    with the right leverage (the laptop screen) they open and close fairly easily, and hold the screen in whatever position you choose. separted from the screen, without leverage, you cant even turn them with your bare hands. takes 2 pairs of pliers and a good amount of effort to move them.
    anyway, just thought that a couple (or even one) of those would make a good hinge for it. I can take picture of one and post it if your interested.
    Oct 2003
    Toronto, Canada
    yes please that's exactly what i'm looking for! now just gotta source them from somewhere.
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Nov 2003
    how bout dead laptops?
    it seems you would want more resistance then less in the car...
    Jan 2004
    I'll post a pic late tonight when I get home.
    Dead laptops is where I got my 4.
    depending on how its setup, there might even be too much resistance in them, kinda thing you would just have to try... plus each pair is a little different.
    2000 Jeep Cherokee
    -CarPC: [_____]50% complete
    -planning done, still need a few parts
    -In-dash motorized VGA is finally out, need $$$
    -Need to replace factory HU
    Oct 2003
    Toronto, Canada
    Problem is, i dont have too many dead laptops lying around here! Time to call some laptop repair stores.
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Jan 2004
    heres a pic of the two that i have. actual hinge part is very small, however most of the metal is needed to securely attach the hinge to the assembly, because there's alot of stress put on the joint.
    2000 Jeep Cherokee
  1. Replies: 21
    Last Post: 08-27-2006, 01:26 AM
  2. Replies: 5
    Last Post: 04-30-2004, 11:25 AM
  3. lillyput--all hype?----long review
    By liquid_smoke in forum LCD/Display
    Last Post: 11-21-2003, 10:44 AM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
  5. Replies: 13
    Last Post: 07-02-2002, 10:54 AM
