yep, use wood for the basic structure and fill it in with bondo...shouldn't even have to worry with fiberglass if you have enough structure with the wood
Hello there!
I think the placement of the tft is best between the shift gear and the black panel and its much more discreet.
Look`s like its the only place i can put the tft though.
Have been reading some about the bondo and the fiberglass..
Maybe a wodden frame 1st as a ground structure?
Really want it to be intregated as a part of the car and looking real nice
Any comments or tips is welcome![]()
OK, that might work.
But what is bondo in swedish.. so i know what to ask for
Checked the placement for the screen Hmm.. look likes the 8 tft is to big
and its nicer with a wide screen so i think im gonna buy the 7 tft touchscreen
But the damn shift gear is right in the middle of the screen
Maybe gonne replan this project afterall
Originally Posted by Power_nisse
Bondo in Swedish, isn't that allmost the same as in Norwegian?
Bondo=sparkel (spackel)![]()
Bonbo in Swedish is Bondo. It's a brand name. It's also called 'auto body filler', 'all purpose filler' and 'all purpose putty'. If you translate any of those last three phrases into Swedish, someone at a hardware store should know what you mean.
Good luck1
Aha.. of Course "spackel"
well im planning of starting with a wooden frame end then use some bondo..
It`s a real pain in the *** to know how to put the screen and make it look good.
But im gonna experiment a lot![]()
Has anyone installed a screen in a 89-95 BMW 5 series?
i have, where do you want to put the screen? theres not alot of room where the stereo goes maybe below a t anangle in the center console.
Ohh and the problem with just using bondo is if its to thick (more then 1/8 inch) its probley gonna crack. use fiberglass then a bondo fiberglass mix. i just wrote about it here Fiberglassing Tips? on the last page
I'd like to see if a screen will fit in the center console at the same angle. Got pics?
