Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
Thread: 2000 Stang mounted LCD w/DVD-RW in-dash
  1. #31
    May 2004
    ehhh its looks ok but u should of paint it to match the shifter bezel....it would look way better
  2. #32
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    I just bought a 2004 Ford Mustang Mach 1 that comes with the mach 460 system. I personally like the sound so I want to hook my carputer pu to the factory system and remove the existing HU. I found this adapter online which claims to be able to hook up an aftermarket HU to the factory mach 460 system:
    http://www.soundgate.com/products/factory/ford.htm
    any ideas? think it'll work?
    thx,
    chris
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
  3. #33
    Mar 2004
    Toronto, Canada
    i found this on stangnet:
    http://forums.stangnet.com/showthread.php?t=482713
    think this will work on my '04 mach 460?
    My XM FAQ
  4. #34
    May 2004
    Ok that Mach460 article was exactly what I have been looking for for over 2 years now!!! Scorpnstail, I've seen that you wanted in another post to connect the PC directly to the stock system. That's exactly what I want to do. I was thinking about this but I found one issue. Follow me here:
    Computer Speaker Out -> 1/8" to dual stereo RCA cables.
    1/8'----|====< RCA1 and RCA2
    Split RCA1 to Left +/- and Right +/- and connect those directly to the tweeter LF+/-,LR+/-,RF+/-,RR+/- on the Metra Harness since it is an amplified signal from the computer.
    Plug RCA2 into the Metra Harness directly.. Will this be a problem with the audio level? This is not a Pre-Amp out really, but an amplified out. Does this have to be converted some how? And if so, with what kind of device?
    HI Lo Adapters The NS60 looks like an idea.
  5. #35
    Dec 2003
    South West, FL
    Quote Originally Posted by tmar89
    Your idea sounds pretty sound and should possibly work .. I do not know enough about car audio to know if it would work or not .. I am going to read that article above and see what I can piece together myself. I will let you know if I come up with anything else.
    Tmar ... Lets continue this conversation over in my post under car audio so we dont wind up hijacking this thread
    Scorp
  6. #36
    Feb 2005
    Austin, TX
    That looks really good... was it all fiberglassed? or what process did you go through exactly to make it? I need to do the same thing to my car, and need someone to point me in the right direction of the whole process. Thanks.
  7. #37
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    I like the first couple of images, but just a thought. If the ciggy lighter was moved, you fill all the space under the edge of the screen for a smoother look.
    Doesn't look like you could get the lighter out to use it ATM anyway.
    4x4 in a turbo stylee.
  8. #38
    Constant Bitrate Willy-Mach1's Avatar
    Mar 2005
    Laurel, Maryland
    Quote Originally Posted by gnat
    Its not that hard to skip the mach system. Forget tapping into it, not worth it. The radio isn't good enough in my opinion.
    Pull the radio, add a 4channel amp, and run your ampd signal back up to the factory wiring in the dash. The tweeters in the 460 are NOT amplified in the stock mach setup so these are good wires to use in order to get your signal out to the doors without running new wires all the way there. Cut your door speaker wires that come from the factory amp, then run your tweeter wires down to them. Wallah, you've ran your amp out to the factory wiring and then from your factory tweets to your door speakrs. Its probably a good idea to replace the speakers too but you can do that later if you don't have the cash right away. Your only held back by yourself, not the mach system!
    Hey gnat....nice setup!!! I have a 03 Mach1 myself which I can't wait to get a carputer into. I like how your screen is set up, that is exactly what I had in mind for mine. Do you have any intall pictures? or perhaps pointers?
  9. #39
    Mar 2004
    Toronto, Canada
    http://pyros.kicks-***.net/CompuMach
    that's what I've done with my mach1 so far... just finished primering the bezel, painting it within the next week
    My XM FAQ
  10. #40
    Mar 2005
    Laurel, Maryland
    Quote Originally Posted by pyros
    That looks NICE!!!!! that is exactly what I want to do with mine. Keep us posted on how it turns out.....I think I'll be starting my project carputer in about 2 weeks. I'm courious to see how the paintjob comes out
  1. Anyone want a Clarion 5.6" In Dash LCD?
    By gguy in forum Classified Archive
    Last Post: 05-30-2001, 11:29 PM
  2. Anyone want a Clarion 5.6" In Dash LCD?
    Last Post: 05-20-2001, 03:44 PM
  3. TFT fold out of dash LCD 6.4"
    By Bj in forum General Hardware Discussion
    Last Post: 03-22-2001, 06:47 PM
  4. Preview of my in Dash LCD install
    By Destin in forum General MP3Car Discussion
    Last Post: 01-27-2001, 11:48 AM
  5. In dash lcd and a computer.
    By Tyler in forum General Hardware Discussion
    Last Post: 11-03-2000, 12:26 AM
