Page 1 of 6 123456 LastLast
Results 1 to 10 of 52
Thread: 2000 Stang mounted LCD w/DVD-RW in-dash
    I finnished this a few weeks ago and thought i would post it. the fabricating only took about 12 hours. the paint is only temporary until i get this 3M paint that is textured like the top of the dash. critique is welcomed and appreciated-
    2002 Alpine Class A RV Carputer in dash w/mounted 10.4 LCD
    This is another project of mine. I dont believe ive ever seen a carputer in an RV, but the application might be better than in a car. This was a clean install and fairly easy. its my second now and i plan on doing many many more. if you like my work, cantact me and i can make quotes on something for you.
    nickkellam@yahoo.com
    May 2004
    Wow, thats not too bad considering the room you have to work with in the Mustang. Unfortunately, I have the 2001 model which has the MACH 460 system that cannot be easily tapped into or swapped out so I had to keep the system and mount my screen over the radio. Its' not too bad but I wish it could be better.
    Low Bitrate NorthGaVigor's Avatar
    Tenneessee
    Why can it not be taken out or replaced?
    May 2004
    Quote Originally Posted by NorthGaVigor
    You are right that it can be taken out but unfortunately, there is no way to tap into the existing MACH 460 amp-speaker setup for the full effect. I can get just the 4 high speakers but the 4 lows run already amplified from the HU and into the amps. I can't get a clean signal and no one makes adapters for this system. So for now I just use an FM modulator which works ok for now. I don't have the money to swap out the whole system just yet.
    Dec 2003
    South West, FL
    Quote Originally Posted by tmar89
    I am pretty sure that this would allow you to tap into the 460 setup
    http://www.logjamelectronics.com/piefrdnaux.html
    at least that is what I am planning for my set up at the moment
    Scorp
    May 2004
    Quote Originally Posted by Scorpnstail
    Scorp
    i've seen this before. Read more on this page:
    NOTE: NOT compatible with 2003 models equipped with the 6-Disc in-dash headunit or factory navigation system.
    Tmar, how did the mounting work right on top of the stereo? Also, how permanant of a setup is it?
    Im new to carmp3, but wanting to build into my '99 cavalier. I might be able to take out my radio, move the controls for AC and whatnot, and install the monitor there. However if not(im not the best at that kind of stuff) maybe I could just mount in front of the radio like you did. Especially if its fairly reversable, i really want to build a carputer but dont know how long I will keep the car for.
    Thanks.
    Dec 2003
    South West, FL
    I figured that since it is the 2001 6 cd changer then there should not be any issue since it is most likely a different unit in the 2003.
    Scorp
    May 2004
    Quote Originally Posted by bsboard
    Thanks.
    I just used the supplied harness with the Lilliput LCD screen and used two screws with locking nuts and went right through my dashboard trim. It wasn't my #1 plan but it works and I'm happy with it. The good thing is that I still have access to my radio for now and I also can easily detach the LCD from the harness for security reasons. if you have a flat area you can use double stickyback tape! good luck!
  1. Anyone want a Clarion 5.6" In Dash LCD?
    By gguy in forum Classified Archive
    Last Post: 05-30-2001, 11:29 PM
  2. Anyone want a Clarion 5.6" In Dash LCD?
    Last Post: 05-20-2001, 03:44 PM
  3. TFT fold out of dash LCD 6.4"
    By Bj in forum General Hardware Discussion
    Last Post: 03-22-2001, 06:47 PM
  4. Preview of my in Dash LCD install
    By Destin in forum General MP3Car Discussion
    Last Post: 01-27-2001, 11:48 AM
  5. In dash lcd and a computer.
    By Tyler in forum General Hardware Discussion
    Last Post: 11-03-2000, 12:26 AM
