Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 68
Thread: Lilliput into E36 developement pics.
  1. #41
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mushupork5
    screen bezel, also how do you plan on securing it to the dash?
    Have to see how it turns out, and how much work it is. I shall be using the mould to make another one as I go along, can't hurt to have two on the go at the same time in case I screw up big time with one.
    The only issue I would see is that the screen might not be in the same place for you. Even if it's out by a couple of millimeters it will make a big difference.
    As for fixing it, not sure, may be a case of letting friction do the job. But also looking at the possibility of putting two screws through the top into the air vent. The air vent already has two screws to fix that, so take them out and replace with longer ones.
  2. #42
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by Enforcer
    Don't you like to see the grapes before they make wine out of them
    Good point.
  3. #43
    May 2005
    enforcer that looks awesome.
    if you ever decide to sell the bezels let me know.
    edit
    you have a rhd 328
  4. #44
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by manuel
    you have a rhd 328
    Wouldn't have thought that would make any difference, the console at that point is symmetrical.
  5. #45
    May 2005
    it looks like it faces the driver by a few degrees.
  6. #46
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It's only the dash piece that is angled, the inner parts are pretty flat.
  7. #47
    Romania
    Any new pics?
  8. #48
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Not at the moment. Just going through the sanding motions when I have time at the moment. Got a second lot of fibre in the mould though.
  9. #49
    May 2005
    hmm interesting, let me know if you decide to sell it then.
  10. #50
    Constant Bitrate ccblanket's Avatar
    Sep 2003
    SF Bay Area
    Enforcer,
    Did you make that frame for visual purposes only? Or does it really hold the LCD in place?
    do you have any pictures of your dash removed? I am trying to do the same but trying to figure out what screws I need to touch to pull that center dash piece off.
    also, how do you like the lilliput so far? is quality ok? are you experiencing the burnt-in dragon image effects?
    rgds
    --hikmet
  1. Step by Step Lilliput dismantle (pics)
    By cadence117 in forum LCD/Display
    Last Post: 02-16-2007, 01:43 AM
  2. Lilliput install pics '03 Sierra Denali
    By rgardjr in forum LCD/Display
    Last Post: 06-10-2004, 01:57 AM
  3. Replies: 44
    Last Post: 06-06-2004, 03:36 PM
  4. Replies: 2
    Last Post: 01-10-2004, 02:07 AM
  5. Anyone got pics of the inside of a lilliput?
    By liquid_smoke in forum LCD/Display
    Last Post: 12-19-2003, 10:52 AM
