Page 1 of 7 1234567 LastLast
Results 1 to 10 of 68
Thread: Lilliput into E36 developement pics.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Current centre console
    Centre console obtained from scrapyard to experiment with.
    Paper tray from WHSmith, it has the same pattern as the Trip computer and the Air Con.
    surround cut out of the tray
    Surround in the Centre Console
    Lilliput in the combo.
    Still need to work on the fixings. Also the filling behind the surround is just a piece of carboard at present, need to get the right thickness plastic to replace it.
    Also got to work on the buttons. Am looking to possibly obtain some nice BMW ones like on the trip Computer or the A/C and cut those into the surround underneath the Lilliput.
    Note the current surround will be replaced with another one as this is just a prototype one (he says excusing himself for the superglued crack )
    Opinions welcome. (runs and hides in corner)
    May 2004
    Curacao, Netherlands Antilles
    VERY VERY nice .... the same texture , (pattern) is really cool , gonna look almost like factory , very nice ....
    wondering where you gonna put the OBC thingy ... temp ,trip , diagnostic stuff ... that thing is really usefull ... i mean it gives the errors and stuff
    edit: one other thing ... its a good alternative of course to putting the screen infront of the vents ... I hate that ... no air .....
    and thinking about it .. maybe you can even mount the OBC diagnotic thing where the radio was ?? (they are both "din" i think LOL)
    Low Bitrate shadowpuck's Avatar
    Mar 2004
    enforcer - that looks great....and, it so happens, is exactly what i'm trying to do with my e36...i will be very interested to see the future development of your project....
    you mention replacing some buttons, are you talking about the ones on the lilliput itself?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    @Q gamelogic, I have seen another E36 where the OBC thing was put into the centre console. You need to extend the cables. I am keeping my headunit so the OBC won't go there. However this is just a first stage, eventually the screen will go up a level to where the stereo and A/C is. However I am finding it difficult to get a breakers to let me take a circular saw to the dashboards in the cars in their stock and the top bit of the dash is very big. So first attempt will go at the bottom, when most of the mechanics are worked out it should be easier to move up. will end putting the stereo faceplate somewhere and having the main body of the headunit tucked away somewhere.
    @shadowpuck, the Lilliput buttons are on a small PCB, looking at them they just short to ground to make the circuit, so in theory it shouldn't be difficult to make my own set of buttons, would like to use some acquired from a OBC or A/C unit.
    May 2004
    you could use buttons like the ones for seat heating ... traction control (ASC)and the convert cabrio button etc ... mounted bezide the cig thingy, those are like 4 pin or 2 pin buttons .... that can be easyly hooked up ... just pop out one of the blind littke faces , and pop the new button in .. very clean and easy ...
    Mar 2004
    @enforcer - that's an idea i hadn't thought of yet...that sounds like a really good idea...one of the things i had been concerned about with the lilliput was that it wouldn't look quite factory with its buttons....however, some salvaged OBC or AC buttons would work perfectly - and look OEM no less!
    @q - i am actually going to be mounting some of my power controls in that area for the computer...i am also going to put the hard drive activity light and such there.... those blanks are great for that kind of stuff....
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    @q, have alreadu used one of those ASC buttons as a remote power switch for the PC, the only thing is there won't be enough for all the lilliput functions, besides That it will mean more wires going elsewhere, want to try and keep it all in one area. Hopefully I'll be doing the Coyote upgrade for the power.
    Hey man, do you have a link to the sourroung piece that you used? I am in the middle of the exact same install, but i cannot seem to fabricate a good trim piece. Help me!!!
    Thanks alot!
    lowry.a@comcast.net
    Yeh i did, maybe you could clue me in to who/what WHSmith is... I live in the states, and have not heard of such a company. Thanks for your help
  1. Step by Step Lilliput dismantle (pics)
    By cadence117 in forum LCD/Display
    Last Post: 02-16-2007, 12:43 AM
  2. Lilliput install pics '03 Sierra Denali
    By rgardjr in forum LCD/Display
    Last Post: 06-10-2004, 12:57 AM
  3. Replies: 44
    Last Post: 06-06-2004, 02:36 PM
  4. Replies: 2
    Last Post: 01-10-2004, 01:07 AM
  5. Anyone got pics of the inside of a lilliput?
    By liquid_smoke in forum LCD/Display
    Last Post: 12-19-2003, 09:52 AM
