Results 1 to 3 of 3
Thread: help with next step BONDO FIBER ?
    Constant Bitrate BOND007BE's Avatar
    Jul 2003
    belgium
    Thumbs up help with next step BONDO FIBER ?
    OKay this is what i got till now
    de alu-plate is gonna serve as mounting point for the plexy like you see in the next pic.
    questions.
    i cut out roughly the Xenarc front out of the plexy glass
    how do i fixate it ? with the hot GLUEGUN ? fiberglassing it ?
    when spraying paint over the plexy should i first sand the plexy ? or just primer or bondo to heal the crashes in the plexy ?
    thanx for any help
    BOND007BE
    the sun always shine
    Maximum Bitrate allenruble's Avatar
    Jun 2001
    somewhere
    plexy glass looks best when painted on the back side .Clean the plexy glass with alcohol . I would not primer the plexy glass. Why do you need the plexy glass why don't just flush mount lcd case right to meatal bracket you made?
    www.sounddomain.com/id/2000mp3ranger
    Mp3 player - 10.4 Allbrite Gigabyte GA-71XEH , 700 mgz t-bird , coolmaster fan , 2x 128 ram + 1 512ram , ATI-RAEON RV100 ,on bd sound , Linksys Wireless-B usb network adapter , 20G IBM TRAVELSTAR
    Jul 2003
    belgium
    because that way i can not DEMOUNT it easy , this way i can assurre the base ALU window is mounted fermly , and the screen with the plexy goes to it .
    plexy oonly one 1 site is not an option , plexy is scratched on both sides ( not new plexy)
  1. For the Audi guys - step by step (bandwidth warning!!!)
    By brrman in forum Show off your project
    Last Post: 05-16-2009, 09:47 AM
  2. Step by Step Lilliput dismantle (pics)
    By cadence117 in forum LCD/Display
    Last Post: 02-16-2007, 01:43 AM
  3. fiberglass or bondo??
    By faiz_23 in forum Fabrication
    Last Post: 05-04-2004, 07:39 AM
  4. step by step JCP-ALPHA
    By BOND007BE in forum General Hardware Discussion
    Last Post: 11-24-2003, 11:10 AM
  5. Buying fiberglassing and carbon fiber products..
    By TintedChrome in forum General MP3Car Discussion
    Last Post: 01-15-2003, 03:56 AM
