does anyone have a pic of the "doors" that were mentioned in the del sol and the navigator?
2002 Subaru WRX - Silver
-FP18G turbo
-Walbro fuel pump
-Modified OEM 840 CC Injectors
-TurboXS: UTEC, turboback, uppipe, intake
-Blitz FMIC
-STI cluster
-17"x7.5" SSR Competitions
-Tein Flex coilovers
-NOS 50 shot
-2004 rear conversion
What type of actuator should I use for the door. I did a quick search and found some actuators, but was not sure how many rpm they should be. What do you think about these, I'm not sure if their the right ones.
Link 1 Link 2
Once the actuator has open fully in one direction does it go in the other direction once the power is supplied?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
check this out http://auto.howstuffworks.com/power-door-lock3.htm
i would go for the lowest rpm possible.
If I use a power door lock actuator will I be able to set different opening limits on them or are they set to one limit?
Also if a power door lock actuator is the wrong one for this use, which one should I use?
Installed
i think they are set to a specific distance, I dont know too much in the area. I just posted the link because it gave some background into how they work. I am actually brainstormin VERY hard on this right now because I want to do it so i can preserve my lilliput's warrenty. Also a suggestion is maybe a scissor-like motion, similar to a window regulator.
I found these while searching on google, I think we might be able to use these. I not sure if they would be perfect for our use. From the looks of the website they seem expensive, but they didn't have any prices listed.
http://ultramotion.com/products/digit.php
http://ultramotion.com/products/bug.php
Installed
Looks a little fancy for me![]()
I know what you mean, I still looking for something that might me in my price range.
Installed
You might be able to do something like that. If you look at how a power window work, see link.Originally Posted by binary.h4x
Power window
If you look at the window upside down you could do the same with the door. Instead of making the door solid you could use cloth like the one used with sunroofs. This way you don't need alot of space, the cloth could be wrikled up or roll to the top.
Installed
