Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: dash cover/ door idea
  1. #31
    Apr 2001
    left field suggestion
    But how about a deskjet type printer motor it's a stepper motor so can be controlled and moves at different speeds.
    Of course the control is the problem needs to be set so it moves the door up slowly maybe control through it's normal interface if you could send it a signal to do a paper feed to move it out and another to move it back.
    slow moving solenoid controlled by PWM (pulse width modulation) from a 555 timer.
    I have a lot of other stuff to do before I get to this stage.
  2. #32
    Dec 2006
    has anybody got any guides on how to do this, or does anybody have any links to some on here?
    Thanks!
    Mark
  3. #33
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    Mark is you have skimmed though previous pages you should have found some ideas.
    the fact that this is noit D.I.Y it's cause every car monitor placement is different, and set up is different
    Yev
    R. T. F. M
  4. #34
    Dec 2006
    Quote Originally Posted by Yevmeister View Post
    Yev
    thanks for the response! does anybody have any designs/pictures of the mechanisms that they have made? i'm a bit stuck for ideas!
    Mark
  5. #35
    Nov 2005
    Chicago
    there this design is calloed tambour
    Where to find track sliding panels
    i have been tied up so i have never finished it
    Yev
    R. T. F. M
  6. #36
    Dec 2006
    Yev
    ideal! exactly the sort of thing i was looking for! thanks for that!
    Mark
  7. #37
    Newbie Relum's Avatar
    Jan 2007
    Moscow, Russia
    У нас на форуме ваще маньяки встречаются
  8. #38
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Relum View Post
    Does that even mean anything? It errored out 3 different Russian/English translators! Spam?
    1.9in x 2.9in -- 47mm x 73mm
  9. #39
    Jan 2007
    Moscow, Russia
    Quote Originally Posted by 2k1Toaster View Post
    It's not a spam!
    Russian is difficult to translate in english. I mean that some my friends are doing some weird devices too.
    I used "maniacs" it means "persistent person".
  10. #40
    Jan 2007
    Moscow, Russia
    May I give you advice to use http://www.online-translator.com/text.asp?lang=en onLine translator if you need to translate from russian to english. It's most adequate translator from russian.
  1. Accord lcd question - placing lcd deeper in dash
    By mykolJay in forum Fabrication
    Last Post: 09-29-2004, 01:02 PM
  2. 2003 G35 Sedan Custom Dash And Computer
    By Izik in forum Show off your project
    Last Post: 08-22-2004, 12:45 AM
  3. temps in trunk vs dash
    By Saurk in forum General Hardware Discussion
    Last Post: 03-14-2004, 10:27 AM
  4. cover over lcd mount in dash?
    By Mp3 V in forum General Hardware Discussion
    Last Post: 05-07-2002, 06:32 PM
  5. cover dash in leather
    By markus00 in forum General Hardware Discussion
    Last Post: 05-03-2002, 08:51 AM
