Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: dash cover/ door idea
    Jun 2004
    Cherry Hill, NJ
    hi guys, i have a 1993 nissan maxima and am planning on mounting a 7-8 inch lilliput and carputer in the dash. however when watching tv i saw a commercial for the scion tc and it gave me an idea. the scion has a slideable face plate that slides upward and into the dash to reveal the stock double din radio. as seen here
    http://www.scionlife.com/gallery/tc/tc09.jpg
    or can better be seen in the customize a scion online demo.
    my idea was to fabricate such a piece to work with my dash using black textured abs plastic. My plan is to mount the lcd in the double din location and have the headunit situated below it. here are some pictures of maximas of the same year as mine to show what kind of area and locations im working with. these are not of my car but show the dash panel in question.
    http://www.cardomain.com/member_page...03_11_full.jpg
    http://forums.maxima.org/showthread....&highlight=lcd
    http://memimage.cardomain.com/member...57_35_full.jpg
    any suggestion as to what kind of hinge or maybe drawer sliders or other hardware that would achieve the desired effect. Any help suggestions or thoughts would be aprreciated.
    Jan 2004
    I saw that same scion commercial that you did and had the exact same idea. I was wondering how I could go about doing it in my wrx. The major issue to resolve as I see it is that there needs to be a slot space created above the monitor, which would most likely involve cutting into the dash in your case. It's hard to make something like that look clean and do it in a way that doesn't crack the plastic or make it warp in weird ways. I think the hinge mechanism could be had with a quick trip to the junkyard. A lot of ash trays in cars have a flip up door that works much the same way. You might be able to take it out and extend it to fit a larger plastic plate.
    Another option would be to find out the part number for that assembly on the tc and find a way to mold it into your setup.
    Good luck, I'll be searching for ways to do this too.
    2002 Subaru WRX - Silver
    -FP18G turbo
    -Walbro fuel pump
    -Modified OEM 840 CC Injectors
    -TurboXS: UTEC, turboback, uppipe, intake
    -Blitz FMIC
    -STI cluster
    -17"x7.5" SSR Competitions
    -Tein Flex coilovers
    -NOS 50 shot
    -2004 rear conversion
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I've had the same idea for a while now, I first saw it done in the Lincoln Navigator. It has a flip-up door in front of the navigation system. I've been thinking of the best way to do this. I'm not sure if I want it to flip up or slide up. I think the sliding door would be much better, but it would involve more work.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    how about those big, single piece garage doors, that are found usually on old houses?
    kind of like this....
    this would probably even allow motorization.
    Dec 2003
    New York
    You could use something like a garage door; I'm just wondering how to make it motorized. I’m thinking you could use one of those motors from the little toy cars that run on a track. Only problem is you would have to control the speed of the motor so the door goes up slowly. I also need to figure out a way to make the door open when you turn the ignition and make it close when you turn off the car, that would be awesome.
    Installed
    Jun 2003
    Fairfax, VA
    you could use the same mechanics as an actual garage door, and you could just use the same remote line as the carputer.
    Jan 2004
    Parma, OH
    I have something like that stock that came on my Del Sol to cover the stereo compartment... it slides down instead of up, and is on a basic hinge type mechanism I think
    1995 Talon TSi AWD, 1992 Lexus SC300... LexusPC is finally almost ready for install!
    Dec 2003
    New York
    700mx6: Does your cover slide down by itself of do you have to slide it manually?
    Installed
    Dec 2003
    New York
    Quote Originally Posted by binary.h4x
    I was thinking of doing something to that effect. Put rails on both sides like a garage door and then use a small motor with some sort of a pulley to slide the door. Then I would connect the power to the ignition so when I turn on the car it would slide up.
    But now how would I make the motor go in reverse when I turn off the car, so the door slides back down?
    How would I stop the motor once the door is fully open so it doesn't keep spinning?
    Installed
    FLAC Chairboy's Avatar
    Jan 2004
    Use a small electric actuator (it's like a self contained hydraulic cylinder, but all electric) with a limit switch. A limit switch makes it so that if you hit one extreme or the other, it stops.
  1. Accord lcd question - placing lcd deeper in dash
    By mykolJay in forum Fabrication
    Last Post: 09-29-2004, 02:02 PM
  2. 2003 G35 Sedan Custom Dash And Computer
    By Izik in forum Show off your project
    Last Post: 08-22-2004, 01:45 AM
  3. temps in trunk vs dash
    By Saurk in forum General Hardware Discussion
    Last Post: 03-14-2004, 11:27 AM
  4. cover over lcd mount in dash?
    By Mp3 V in forum General Hardware Discussion
    Last Post: 05-07-2002, 07:32 PM
  5. cover dash in leather
    By markus00 in forum General Hardware Discussion
    Last Post: 05-03-2002, 09:51 AM
