Results 1 to 10 of 12
Thread: carbon fiber
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    carbon fiber
    Ok I was reading on this site: http://web.njit.edu/~cas1383/proj/FAQ/index.htm
    And He Said Laying Carbon Fiber And Fiberglass was the exact same...
    Has anyone had experience with laying carbon fiber? I was gonna make my sub enclosures out of fiberglass with a layer of carbon fiber over it to make it look nice, and was wondering how hard or easy this would be
    Jul 2004
    NH
    my dad has done it and he said its the exact same...
    why would you layer CF over fiber? why not just make it CF? i cant imagine it would take much more CF to make it strong enough.
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Quote Originally Posted by jrich523
    Because fiberglass is much cheaper, this would be similar to putting veneer over MDF instead of using sold hardwood, much more economical.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Jul 2004
    Tampa, FL
    exactly
    Jun 2004
    Bay Area, California
    first thing, make sure you use epoxy resin, not polyester. the epoxy is less thixotropic, and can wet teh fibers much better than polyester. the medium cure side B should dry the clearest, fast and slow cure will yellow slightly.
    I reccommend leaving a texture, rather than finishing glass smooth. itll lose the 3d nature of the carbon, but it will look totally awesome and be unique from liek a carbon hood or something.
    when you cut it, cut it WAY big, the fibers will jsut call out on teh edges. furthermore, dont even lay anything on the carbon. when I was cutting carbon, I laid the scissors right on the cloth, and hte hinge screw on teh scissors tore the carbon and put a permanent dimple in it.
    go out and get yourself a squeegee, itll make your job 10x easier. the carbon is a weave, so it will conform to compound corners. once dry laid, you can pour your epoxy on and spready it with the squeegee. always always always make sure its uniform, never ever do a thick layer of resin. you are jsut asking to get nonuniformities, and once you ahve to sand, you ruin the finish without boatloads of work.
    good call using it as a veneer, make sure your glass under is vinyl smooth, carpet smooth isnt good enough.
    and good luck!
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    where does one buy the raw carbon fibre from ? and from my understanding of the process involved, the carbon fibre made the way fibreglass is made wont be as strong as carbon fibre made the way the professionals do it, in an autoclave
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    FS = MTSVO motorised in dash screen pm me for details
    Jun 2004
    Orange County
    You can buy basically everything you need here http://www.icancomposites.com/
    and you can also check this forum for very helpful tips/tutorials http://www.carbon-werks.com/forum/
    Lexus SC400
    Subaru WRX Wagon
    Jun 2004
    i like a local brick and mortar store www.tapplastics.com
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    That carbon-werks site is amazing! I never knew you could do stuff like that at home!
    Newbie bathbiggles's Avatar
    Jun 2004
    Marlow, England
    where do autoclaves come in then? i thought these were essential in cf work?
  1. Skin Presentation Thread
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-27-2004, 08:44 AM
  2. carbon fibre skin
    By chris-uk in forum MediaCar
    Last Post: 05-25-2004, 05:41 AM
  3. What material to make bezel with?
    By wysocki in forum Fabrication
    Last Post: 05-14-2004, 12:57 PM
  4. carbon skin
    By liquid_smoke in forum ME Archive
    Last Post: 01-13-2004, 04:22 AM
  5. Buying fiberglassing and carbon fiber products..
    By TintedChrome in forum General MP3Car Discussion
    Last Post: 01-15-2003, 03:56 AM
