Results 1 to 7 of 7
Thread: Does anyone want to build a fiberglass mold?
    Newbie SecretSpyder's Avatar
    Jul 2004
    I have just started this website
    www.toshibaportege.com
    I was inspired after spending months reading the mp3car forums. The basic idea is to get cheap easy to find laptops like a toshiba or IBM and turn it them into the ultimate car entertainment center. Because pentium II laptops only cost $100-200 on ebay the whole system should cost less then $500 to build including touch screen. I have already selected and purchased all the hardware and now need to build a case.
    My orginal plan was to build a metal case but after looking at some finshed projects fiberglass looks way nicer. I have mechanical drawings of the case I need to build, I am hoping I can find someone that can turn the drawings into a mold so I can cheaply and easily build it. I am willing to pay for this.
    Can anyone help me?
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Post a pic of the piece that you need a mold of. Is it just a decorative faceplate? Here's some info on making molds: http://www.fbodyaudio.com/articlevie...cle=molds.tech
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Jul 2004
    Badly drawn picture of what I want
    Ok so I know I'm not good in photoshop.
    http://www.toshibaportege.com/ibook.jpg
    What I am want to do is have two fiberglass molds. One for the bottom that would just be flat a curve up at the sides about 5mm. The top part would have a cute out for the LCD and the same curves. I could the make metal brakets for the video out and power and bolt them to the sides of the fiberglass molds to complete the case.
    I have already put so much work into getting all the hardware I don't want to spend the next 3 months making a case. Here is the hardware that's going inside the box.
    Toshiba portege Pentium 300Mhz 192Mb Ram
    Touch Screen with touch contoller
    DC power supply
    FM Modulator to broadcast to FM channels
    Battery back up
    Shutdown controller.
    I have seen some people on the forums make some really aweome looking cases and want to do the same.
    I am still trying to get dimensions for the touchscreen controller and FM Modulator. Once they are done I can do mechanical drawings.
    Constant Bitrate coachreed's Avatar
    May 2004
    Lee's Summit, MO, USA
    Are you looking for info on how to make your original case, or how to make molds from that so you can mass-produce the case? If you are trying to replicate an original, the key is to have the "plug" (original model) as PERFECT as possible right down to cosmetics such as PERFECT paint and everything... that is the key to having good reproduction. If you are looking for info on how to make your original... well, thats a completely different story. Be more specific and we'll go from there.
    TTYL!
    Coach... aka Randy!
    Nov 2007
    I can do this
    I can build the box if you still need someone just email me the drawings on it or mail them to me my email is smlldnl@yahoo.com and my address is 5940 Reuben Rd. Mulberry AR 72947
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    woah, registered and everything just to tell someone from 3 years ago that he can build something. I'm pretty sure since the website in the OP is gone, the OP has probably moved on to other things...
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 03:30 PM
  2. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  3. fiberglass or bondo??
    By faiz_23 in forum Fabrication
    Last Post: 05-04-2004, 06:39 AM
  4. tip link for different fiberglass construction
    By kirk fogg in forum Fabrication
    Last Post: 04-15-2004, 09:42 PM
  5. Non-permanent fiberglass mount
    By Chairboy in forum General Hardware Discussion
    Last Post: 03-21-2004, 03:33 AM
