Results 1 to 10 of 19
Thread: Preparing the dashboard/console
    Registered User Chronyx's Avatar
    Jul 2004
    Surrey, England
    Hi guys,
    How easy is it to cut the right shape into the dash? How do you relocate the heater controls (not the switches, which would be easy I imagine, but the part that controls where the air goes...on my car it's controlled manually (not eletrconic) so I'm not sure how I'd do that.
    Basically, any info you guys can give me for trying something like this for the first time would be brilliant - and don't not post anything because it's 'not worth mentioning' or something - trust me I'm sure I'll find it useful!
    Dallas (Grapevine)
    I have had trouble getting responses on the same question, but I thought I would offer what I have found. I will assume you want to mount your screen in the dash. Maybe if we pool our knowledge we can help each other out.
    I have a 99 Chevy Tahoe. The stock radio is a 1.5 din, with the A/C controller located just below it. Below the A/C control is the stock CD player (a seperate unit). These three items sit in the space I want to use for my screen. See the attached pic.
    First off there are a few other choices I thought about before deciding I wanted it actually 'in' the dash. One is to order one of the motorized units from digitialww. These are basically a standard radio (1 din) sized box that Armen (owns digitalww) has modified to hold the screen horizontally when not in use. When you power the unit on, a motor ejects the screen. See this link, in particular the pic at the top:
    http://www.digitalww.com/DWW-7VGT.htm
    Another way is to use the swivel basemount; screw it down to a surface and you are done.
    http://www.digitalww.com/VGA_TM_710VG.htm
    Those are the easy ways to get by. But I had visions of my dog trying to use the screen as a step (we travel occasionally on long trips) so I had to ditch 'em and mount it 'in' the dash.
    The screen itself is taller than the 1.5 din radio opening, and narrower. So I realized that I must move the the A/C controller down to where the stock cd player is to open up the height, and somehow fill in the sides of the opening with something to make it look stock.
    Without going into detail about what will have to happen behind the dash, I have determined that I will have to most likely move the 4x4 switch (to the left of the cd player) to a new home (hoping this is electronic, so I can move it to a smaller set of switches instead), remove the stock CD player completely, and move the AC control into that left over opening.
    That will give me the factory radio opening as well as the opening below it to mount the screen.
    I will have to next cut off the divider (in pic, the one that divides the radio from the AC control) and probably toss it out. I will then use wood to make a basic frame around the sides and bottom of the screen and place it in that opening. Lastly I will have to shape this frame, with the intent to make it look factory (see in pic how the dash bezel has curves on the corner instead of a straight 90 degree corner) and blend it with the remaining pieces.
    I will probably then coat the whole dash with bondo or something similar so there are no lines showing. This will leave the dash smooth, with my wooden screen bezel hopefully looking factory.
    Last step is to apply some texture paint to the now bondo'ed dash to match the rest of the plastic around the car, and paint or dye it to match.
    Hopefully this gives you some ideas... I would really appreciate any you might have to offer as well since I really hardly know what I am doing.
    Dallas (Grapevine)
    oh yea, and this AC contoller is not electronic either. It uses vaccum lines, some electronics, and possibly a cable. I am hoping by moving the controller such a short distance I wont have to mess with those. But if I do, I will have to extend the vaccum lines with extra hose (probably from an auto parts store), lengthen the wiring, and possibly extend a cable. The cable is the hard part... Since I haven't gotten there yet I can't give more details, but other than the cable itself, the rest could be easily lengthened.
    Jul 2004
    Surrey, England
    That's an excellent answer, thanks mate.
    I'll try and get some pics of my dash and explain my ideas!
    Thanks again
    FLAC Chairboy's Avatar
    Jan 2004
    Slushikien,
    I have the same dashboard in my 99 Yukon, and it's incredibly easy to get off. Just open the cup holder and pull on the plastic, if I recall correctly I didn't even need to use tools. You can then check out everything behind the dash in a snap.
    That auxilary CD player is the same size as a PC 5 1/4 bay device like a CD-ROM, so you could definately replace it with something nice that's designed to go into those on PCs, from a DVD player to maybe one of those multi-function things that have temperature sensors & usb/firewire ports. If you're getting rid of the factory headunit, then you're getting rid of that player too, so why not?
    Living vicariously because my wife won't let me cut up our Yukon,
    Chairboy
    Constant Bitrate saikano's Avatar
    Jul 2004
    Huntsville AL
    i want those smilies....
    don't let a day go by without finding some wonder in it...
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    You must jack them from other forums then...
    Find the smilie you want at another forum, right click on it and hit properties. copy the image location.
    When posting click on the image button to enter an image and make it show up properly. preview to make sure you got it right and then post
    Dallas (Grapevine)
    Thanks ChairBoy didn't know that is a correct fit for that...
    But I still think I won't be able to use that to my advantage. Unless you had another idea to offer, I can't think of any place to move those AC controls but down into that CD tray area. No other place to fit them that I could find...
    Dallas (Grapevine)
    Quote Originally Posted by Chronyx
    Thanks again
    I'll be holding you to that Thanks for making me feel good about the 45 minutes I spent on that instead of getting to work like I am supposed to
    Jul 2004
    Surrey, England
    Right, I have now got some pics! As you can see I've got a fair amount of space to play with - there isn't a passenger airbag on my car, so that space is usuable.
    I have quite a reasonable amount of space on the centre console - the ash tray, cubby hole, radio and switches can all go or be relocated - it's just the mechanical heater controls that have to stay in place (as far as I know!)
    The ball has started to think about the possibility of a chance of rolling!
