Page 6 of 6 FirstFirst 123456
Results 51 to 59 of 59
Thread: HOWTO: Building a removable LCD screen bezel and mount
  1. #51
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    Yeah if you cover it with bondo you can't cut away the foam ... from the front ... but you can scoop it out the back! It leaves sort of a bondo shell that you can reinforce by applying layers or filling from the back. By the time I was done there was almost no foam insulation left. If you can only work from the front side you probably need to use something a little more hearty than spray-foam for your initial form. Soft wood such as balsa would probably work better. There is also a formable product that you can carve easily called BalsaFoam that you could investigate. This is going to be more structurally sound than other alternatives.
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
  2. #52
    Newbie 88Vette's Avatar
    Jun 2006
    Houston, TX
    I was very impressed by your work!
    Could you please send me a working link to d/l the procedure from or shoot it over via email?
    Please PM me if you can.
    I am going to try that for my 88 vette. I'm removing the passenger side dash hump that sticks out and replacing it with the flat piece so i can cut a hole and mount the bezel for my Lilliput 7" LCD for the carputer.
    Thanks mucho!
    David
    Houston, Texas
    eBay:Davidnclearlaketx
    ** 99.5% Positive! **
  3. #53
    Aug 2003
    Amarillo, TX
    I'm not sure I understand what you mean by 'download the procedure'. 100% of the writeup and images on how to do this is in the first post of this thread, which I assume you have already seen.
    MY CAR IS FOR SALE!
  4. #54
    Low Bitrate keyvan's Avatar
    Dec 2005
    Orange County, CA
    Gork, excellent job, excellent write up. Thanks alot. I am however having the same problem as the fellow a few posts before me as to how you actually remove foam when you've covered it with bondo.. You said scoop it out the back.. Well arent we covering the whole face entirely with bondo? if you were to scoop out chunks of foam and fill it in with more bondo, wouldnt you still have foam in the middle portion? I don't see how I can do this without leaving foam majorly part of the inner structure. Are we intending for it to be this way? Thanks alot!!!
    1997 Mazda Miata, Black
    MiataPC
    In-dash Fabrication
    Current dashboard: http://www.aescarpc.com/miatapc/2
  5. #55
    Newbie Wahmba's Avatar
    Aug 2006
    Austin, TX
    Hi Gork,
    First let me say you do great work - from a fellow Texan (I'm a 12 year transplant from Pittsburgh). It's very meticulous and clean! Nice car also.....I have a black '04 that I love. I am thinking of putting in a car pc for NAV, DVD and MP3's, but I don't want to change the stock look much. I plan on making a removable bracket to hold the touch screen and keep the existing HU for FM and CD's. In your M3, how hard was it to tap into the existing wiring behind the HU? Is it possible to run the pc and the HU using the same wires for audio?
    Any help you could give me is GREATLY appreciated. Thanks!! Take care.
  6. #56
    Aug 2003
    Amarillo, TX
    If you keep the stock head unit and want to run the PC's audio into it, just get the auxillary input kit from BMW. Your '04 will have no problems with this and you won't have to tap into anything at all. The kit gives you a standard stereo 1/8" miniplug which you can hook up right to your sound card line out.
    MY CAR IS FOR SALE!
  7. #57
    Aug 2006
    Austin, TX
    I didn't know it had that capability.....Thanks!! You know the car well! Later today I'll post pick of my install in my Dad's '02 Envoy - He's the one who got me thinking about doing a pc in my car. His is the first pc install I've done. Take care Gork!
  8. #58
    Jan 2007
    Sheffield, UK
    Can you make another?
    Hi, i live in the UK and I am looking at buying a BMW 320 Cd M, it has the same dash as yours. Would you and if so how much would you charge to make a bezel?
    Sy
  9. #59
    Apr 2009
    Nice Work
    Hay Do you take order if I would like to place a one.
    let me know.
    it for s430
  1. Dash mount screen in GM Chevy Tahoe
    By slushieken in forum LCD/Display
    Last Post: 06-19-2006, 04:31 PM
  2. ibm thinkpad lcd screen
    By c a m a r o in forum LCD/Display
    Last Post: 06-27-2004, 03:57 PM
  3. mount LCD w/o housing - lilliput 619
    By cybermob2 in forum LCD/Display
    Last Post: 05-04-2004, 04:14 PM
  4. Where to get a ceiling bezel for 7" LCD
    By NightHunter in forum LCD/Display
    Last Post: 03-21-2004, 04:18 PM
  5. Before you use foam to mount your Touch Screen
    By NewTechFool in forum LCD/Display
    Last Post: 03-05-2004, 02:33 PM
