Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: no0b...how do i go about removing my dash? i can't see any bolts!
  1. #31
    Constant Bitrate saikano's Avatar
    Jul 2004
    Huntsville AL
    oh yeahh, i forgot to mention that i don't know jack [or his brother] about soldering. well, actually, i do. i know how to pronouce it!
    so uh, i'm gonna head down to my local radio shack and bug the guy in there to teach me how to solder [i'll catch on fast, i believe]. if he's no good, i'll go to this local short wave radio/computer store here in town. someone is gonna know how...
    what might help too, is if someone [looks around at the forum] did a step by step breakdown of their lilliput, with zoomed in photos of what to solder and stuff
    wouldn't hurt to tell me what size soldering iron to use, and what type of solder...
    anyhoo....
    i'm outtie.
    don't let a day go by without finding some wonder in it...
  2. #32
    Jun 2004
    Quote Originally Posted by saikano
    anyhoo....
    i'm outtie.
    people at radio shack don't know crap anymore.. find you a good electronic store in town.. one that just sells electronic components (ie capacitors, resistors, circuit boards, etc) radio shack nowdays has just a cabinet with a fwe switcheds, etc in them... times have changed
  3. #33
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    more picks
  4. #34
    Jul 2004
    Huntsville AL
    lawrence:
    so uh...wanna tell me where you found those...?
  5. #35
    Oct 2003
    i am a tech at a new car dealer i have a membership to all data pro
    here are the rest sorry about the delay
  6. #36
    Oct 2003
    more picks then i will send text
  7. #37
    Oct 2003
    the picture order is---
    #312
    #893
    #894
    #588
    #312
    #449
    #314
    #315
    #316
    #317
    #318
    1 Negative (-) battery cable.
    2 Disable the SIR. Refer to Disabling the Supplemental Inflatable Restraint (SIR) System.
    3 Pull out instrument panel compartment while pushing its stopper from both left and right sides.
    4 Two plastic hinge pins and instrument panel compartment.
    5 Two screws and set aside hood release handle.
    6 Two screws, three bolts and passenger-side SIR module.
    7 Two plastic retaining clips, two screws, two electrical connectors (if equipped with power windows) and parking brake lever bezel from vehicle.
    8 Two screws, two plastic retaining clips and lift console.
    9 Power/Normal switch electrical connector (if equipped with 4-speed A/T) and remove console from vehicle.
    10 Ashtray from guide by depressing spring-loaded tab and pulling ashtray out from the guide.
    11 Four knobs from heater control unit.
    12 Heater control unit face plate from center trim bezel by pulling straight out.
    13 Illumination lamp bulb socket from heater control unit.
    14 Four screws and center trim bezel.
    15 A/C switch electrical connector (if equipped).
    16 our screws, two electrical connectors and radio.
    17 Four screws and knee bolster trim panel.
    18 Pull gently top portion of knee bolster trim panel to release two retainers.
    19 Two bolts and knee bolster from instrument panel.
    20 Steering column.
    21 Four screws and instrument cluster bezel.
    22 Four screws and instrument cluster assembly.
    23 Three electrical connectors and speedometer cable from instrument cluster assembly.
    24 Mode and temperature control cables on right side of heater case.
    25 Fresh/Recirculation control cable at blower case.
    26 Blower switch electrical connector and heater control unit from vehicle.
    27 Instrument panel harness electrical connectors.
    28 One screw holding left side of the instrument panel support beam to vehicle.
    29 One screw on bottom left side of instrument panel.
    30 Left side instrument panel support beam cover and two bolts.
    31 Right side instrument panel support beam cover and two bolts.
    32 Left and right screws at bottom of instrument panel compartment support.
    33 Two front speaker grills and instrument panel upper center cover with flat-bladed screwdriver.
    34 Three screws along top of instrument panel.
    35 Pull instrument panel from support member.
    36 Instrument panel from vehicle.
    reverse to install
    hope this helps
  8. #38
    Oct 2003
    also disconect battery for at least 10 minutes to disable air bag .
    then it will be safe to then work on dash
    and dont connect battery & turn key on without air bags hooked up or it will set a code for an open circut in the air bag control unit.
    air bag code almost always will need to be reset by the dealer $$$$
    let me know if this helps
  9. #39
    Jul 2004
    Huntsville AL
    wow
  10. #40
    Mar 2007
    bringing up an old thread.
    What about removing the Jeep compass front bezel?
    I got the replacement, and it looks like 4 snaps, but what would i do? get a screwdriver and pry?
  1. dash cover/ door idea
    By cyberpotato in forum Fabrication
    Last Post: 01-15-2007, 06:47 AM
  2. hacking radar into dash.
    By lstrunk in forum General Hardware Discussion
    Last Post: 08-31-2004, 03:04 PM
  3. How can i fit my in-dash housing into this dash?
    By Slitha in forum LCD/Display
    Last Post: 08-08-2004, 01:14 AM
  4. temps in trunk vs dash
    By Saurk in forum General Hardware Discussion
    Last Post: 03-14-2004, 11:27 AM
