Results 1 to 7 of 7
Thread: Own Distrobution Block?
    Variable Bitrate cheerio's Avatar
    Jun 2004
    San Antonio
    Whaat would be the best way to make a distrobution block for acessorys, say lights, lighted switches, radar detectors, psu, alarm, etc, etc/
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    Something wrong with the ones you can buy?
    They're quite a ***** to make if you want one that's safe.
    Jun 2004
    San Antonio
    i would rather have 1 big distro block, then like 2,3, or 4
    May 2003
    Texas
    Then buy one big distribution block.... Your not going to be able to fill up even two - 2 ga. spaces on a distribution block with all those 12-14ga. wires.
    An alternate solution would be to have a large 12v wire running behind the dash and just tap and solder where you need to get power to things. Tape the soldered areas with electric tape of course.
    Jun 2004
    San Antonio
    well, i would like to have it sorta like a factory distro block, with fuses to each item
    Dec 2003
    Michigan
    Go to any boating/RV store, but a 12V fuse block (they make them as big as you'd ever want). That is what you are looking for.
    2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
    Low Bitrate djtrickee's Avatar
    Aug 2003
    Denver, CO
    Painless wiring makes good products for what you are talking about.
    h**p://www.painlessperformance.com/fuseblock.htm
  1. Keypower 250 watt - Stock battery - No reboot on crank!
    By LESLIEx317537 in forum Power Supplies
    Last Post: 03-28-2004, 11:10 AM
  2. New on the Carpc Block
    By e_z_street in forum Newbie
    Last Post: 02-09-2004, 11:56 PM
  3. FS: Power Dist Block
    By SavageKabbage in forum Classified Archive
    Last Post: 02-06-2004, 08:51 PM
  4. Replies: 5
    Last Post: 01-08-2004, 12:38 AM
  5. Replies: 16
    Last Post: 06-25-2002, 02:16 PM
