Page 5 of 5 FirstFirst 12345
Results 41 to 47 of 47
Thread: respirator vs. dust mask
  1. #41
    Jun 2004
    Bay Area, California
    yeah, curiosity, thats exactly what I was talking about. my numbers were obviously way off, but I expected that.
    considering fibers, we all should know that carbon fibers are generally way way smaller than silica fibers. When I did a failure analysis project on a kestral road bike carbon frame, I measured the fibers to be 12 micron in diameter. I was sanding that thing down all day, i didnt care.
    if your report is credible, then thats the magic formula for cancerous causing agents in the lungs, from our functional standpoint.
    the greater danger, for us, would be something along the lines of a fiber getting in the eye, then foolishly dropping the grinder we were using to sand the glass, right onto our leg or something.
    but the dust actually causing more than irritation? I cant imagine any "hobbyist" awho will have those kinds of exposure times!
  2. #42
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    So what you're saying is, the fibers will only irritate the tissue, but what about in conjunction with the all rest of the hazardous ingredients? Obviously, these particles are going to be smaller and along with a little fiberglass to improve the passage it seems like a winning combination. I still wouldn't tell others to do something simply because I haven't been diagnosed with a terminal illness... yet.
  3. #43
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    so what kind of filter do we need for fiberglassing??? my respirator, which i just bought the otherday, said u didnt need to replace the cartridge until your atrted to smell sumthin while using it... well only about 5hrs using it and i smell sumthin, maybe its not tight enough but to be safe i wanna make sure i have the right cartridge, i have an organic cartridge right now is that correct?
  4. #44
    Dec 2003
    Michigan
    Another option is a gas mask. Sure it sounds odd, but if you're not going to do this over and over and over, check into a local army surplus store. The one in town here has Israli gas masks with a new cartrige fore about $18. You can get more expensive German, and even US masks, but eh... Not to mention, that a gas mask will protect your eyes as well, and I would have to believe that it will work better than any respirator. AND, when the big one comes, you're prepared :P
    2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
  5. #45
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    Quote Originally Posted by Jackso
    i have a german gas mask from a world war..dont remember which one. its um...
    a) not comfortable
    b) low visibility
    c) not comfortable
    d) overkill for fiberglassing
    just spend $15 for a respirator.
    rebuilding carpc... kinda..
  6. #46
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    Gas masks are designed to filter out poison gas. Not bondo.
    If you're going to go out and buy something for bondo work, use some common sense and buy something designed for working with bondo.Theres a right tool for every job, why the hell would you go out of your way to hunt down a functionaly questionable relic from world war II that isn't designed to do what you are doing?
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
  7. #47
    May 2004
    NJ
    Here is a fact, Red Cherry, the one used in cocktail drink causes cancer according to the FDA, Do you know how much would cause cancer, if you consume a case of 24 cans a day for 20 years!
    I am not againest the facts listed above. Please follow them.
  1. After the dust has settled......
    By magnetik in forum General MP3Car Discussion
    Last Post: 09-25-2002, 09:58 AM
  2. Can't seem to get rid of the dust...
    By SuperMatty in forum LCD/Display
    Last Post: 09-15-2002, 09:44 PM
