Are you sure you don't have any bumps or uneven spots in the frame that the LCD is in? I'm assuming it's the front of the lilliput case, but if it has superglue chunks on it, that would cause some problems. You should try sanding it all smooth. The TS doesn't like things pushing against it.
LinkBack URL
About LinkBacks
But I bought another one from BadAndy4You. Also the edges of the dash piece were pushing on the touchscreen too hard causing it to think it was being pressed.
I'm thinking about using some of those little foam rubber standoffs in the corners...dunno
