Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Having problems with paint-Weird frosting effect
  1. #11
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    do you think putting it in a room with a dehumidifier would help ?
    CarPC install is starting to come along again...
  2. #12
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by Grayscale
    Maybe, it will not 'hurt' it it. Mostly we do not have high humidity problems in Colorado...
    TruckinMP3
    Read the FAQ!
  3. #13
    May 2004
    Arkansas
    its horrible in arkansas. i'm going to go to some paint shops around here and also try this body shop/paint shop
  4. #14
    Jul 2004
    There are two types of paint.
    I don't know the names of them in english.
    I thought is had something to do with the lead in it.
    When you mix these types up (using a primer of the first, and a collor of the second) you get this kind of troubles.
    Did you allready think of that?
  5. #15
    Jun 2002
    Colorado
    In the US you can not buy lead based paint anymore, Federal regulation prohibits it.
    This has been true for years. You may be thinking of acrylic vs laytex.
    TruckinMP3
    Read the FAQ!
  6. #16
    Jul 2004
    YES! thank you!
    Here in Holland it should not be provided also, but sometime's I see a can of laytex based paint comming across...
  7. #17
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    Quote Originally Posted by TruckinMP3
    acrylic = latex.
    i think you mean latex or oil (alkyd) based paints.
    latex stays on top of what you are painting while oil seeps into it. you cant paint latex over oil but not the other way around
    if you paint oil over latex, it will not hold and will tend to feel mushy.
    i think 88F may be too warm with that humidity. what might be happening is the top part of the paint is drying first. try painting in a cooler environment and let it dry as naturally and completely as possible. dont put it next to heat lamps or anything. it might actually take a day or two to cure fully. of course, if you're going to apply more layers of the paint, you'd probably want to lightly sand it and repaint before it cures completely.
    rebuilding carpc... kinda..
  8. #18
    Jun 2002
    Colorado
    Quote Originally Posted by fantomas
    acrylic = latex.
    Yes, I had it wrong, sorry about that.
    TruckinMP3
    Read the FAQ!
  9. #19
    May 2004
    Arkansas
    my friend told me its because i need more primer on it...and i dont know which kind of paint i'm using...anyone know how to tell?
  10. #20
    Nov 2003
    CT
    read the label?
    latex paints usually dont have that much of an oder to them (compared to oil based paint). latex is also water cleanup (can wash hands and brushes with just soap and water) while you need paint thinner to clean oil based paint.
    what brand is the paint and primer? if you know the brand and product line, it shouldnt be too hard to figure out.
  1. Weird touchscreen problems
    By claylong in forum LCD/Display
    Last Post: 02-25-2003, 08:46 AM
  2. Lorty's plugin display problems, really weird
    By dudah85 in forum Software & Software Development
    Last Post: 08-08-2001, 12:59 AM
