Results 21 to 30 of 31
Thread: Having problems with paint-Weird frosting effect
  1. #21
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    its duplicolor universal flat black and duplicolor sandable filler primer. they both stink bad, must be oil based. and its spray painted, so i dont use brushes. but i know when i get the paint on my hands its hard to wash off with soap and water...it just sticks.
    CarPC install is starting to come along again...
  2. #22
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    yup, thats oil.
    rebuilding carpc... kinda..
  3. #23
    May 2004
    Arkansas
    so oil is gonna mean im going to need a really good primer so it wont seep in or what? will bondo "soak" up the paint?
  4. #24
    Nov 2003
    CT
    it must be an oil based primer so the paint can seep in. i have no idea in regards to the qualities of bondo..
  5. #25
    May 2004
    Arkansas
    wait do i WANT the paint to seep in or not? if its an oil based primer that means the oil based paint WILL seap in?
  6. #26
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    The two basic automotive-type paints are lacquer and enamel.
    It doesn't sound like this is the problem, but you can spray enamel over lacquer, but you can't spray lacquer over enamel. There are special primers that will let you do that, but regular primer will be one or the other. If you spray lacquer over enamel, the paint will wrinkle and bubble.
    If you put several coast on and it's still hazing, it sounds like either a bad batch of paint, or as you suggested, the temperature. If moisture is getting into it, it could what's causing the cloudiness.
    Good luck,
    Kris
  7. #27
    May 2004
    Arkansas
    thanks! going to the paint place today (hopefully)
  8. #28
    Jul 2004
    Grayscale,
    Sand sand sand...that should help eliminate your paint problem...I'd go down to 1600...or lower grit...and wet sanding helps...then hit it with primier, wet sand that a bit...before the first coat of paint.
  9. #29
    May 2004
    Arkansas
    oooo thats a lot of sanding...well i talked to the paint place and they told me to paint the paint on thicker...and VIOLA!
    Turns out the paint was evaporating too quickly causing the pigmentation to not set in. I guess I was spraying too light of coats. And the breeze didn't help, made it want to dry faster. I just painted it today during my lunch break, looks excellent! I'm so happy now! All that bondo/sanding work is done!
  10. #30
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Yea!
    TruckinMP3
    Read the FAQ!
  1. Weird touchscreen problems
    By claylong in forum LCD/Display
    Last Post: 02-25-2003, 08:46 AM
  2. Lorty's plugin display problems, really weird
    By dudah85 in forum Software & Software Development
    Last Post: 08-08-2001, 12:59 AM
