Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 77
Thread: Custom faceplates & cases... interested????
  1. #51
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Quote Originally Posted by englsh
    ... think a slot (& probably mounting hardware) built into the faceplate would be a cool idea to have the slot load CD either above or below the screen. What are people's thoughts on this??
    Make it above the screen! Making it below would disable people to mount additional deviced behind the screen, if there will be enough place otherwise. Imagine all-in-one solution based on VIA Epia. Double DIN housing with 7.2 LCD faceplate in front, MB on bottom of housing AND slim drive on top with some more space to mount HDDs and other parts in between them.
    Now just someone make it happen. I have not enough tooling to do so.
  2. #52
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by phatbenny
    I would definately be up for buying a double din faceplate from you. I have a '95 BMW E36 and want to put the screen in the double din area where the sunglass holder and OBC is. I would prefer to get a lilliput. As far as the slot load goes, I'm interested in principle, but I don't think the area I want to put it has the depth. I'm also based in the UK so it would be really handy if you did this.
    I'm also amazed liliput or xenarc haven't done this. There are a hell of a lot of cars out there with double din slots. There are also plenty of companies selling these screens for in car entertainment purposes. I'm sure this project could be quite a profitable thing for you.
    Cheers
    ben
    that was my original idea.
    take a look at this thread
    Lilliput into E36 developement pics.
    however, I ended up putting it in the top double DIN.
    Lilliput 7" Touchscreen in E36: How's the fit?
    if you look at the last post on the second page, you can see a lilliput in the E36 dash.
  3. #53
    Constant Bitrate phatbenny's Avatar
    Jul 2004
    Birmingham/London UK
    @enforcer: looks like a great install. Any chance of a description of how you did it and maybe some bigger or hi res pics.
    Cheers
    Ben
  4. #54
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    @enforcer: looks like a grat install. Any chance of a description of how you did it and maybe some bigger or hi res pics.
    Cheers
    Ben
    Working on a howto, however still in the process of upgrading bits and pieces so it is slow work.
    Should have done it as I was doing it but forgot
  5. #55
    Constant Bitrate Lando's Avatar
    Apr 2002
    Custom Mold
    I have a mock up of a plastic mold that I was wondering if you could make for me. It is basically a Xenarc headrest shroud that I bought and moded using cardboard and black masking tape. The pattern is kind of intricate, but I think it could be mass produced. It is basically a modefied bezel that converts the Xenarc into a flip down monitor and puts the Slim/Slot Load Panasonic DVD drive and a graphic fan control display behind the monitor. When I finish I'll post pics and you can tell me what you think... maybe??
    Aut cum scuto, aut in scuto
  6. #56
    Nov 2004
    I'm interested
    Looks like you've had a lot of feedback. I figured that I would add to it by saying that I would definately be interested. You said that you had an Audi A4 that you were doing the mold for? I have a VW Jetta A4 body style. I think Audi and VW share a lot of styling although I'm not sure how close the interiors are. I'd be interested in a mold for the VW Jetta A4 body style. Keep us informed on the progess as it seems you have a lot of interested people.
  7. #57
    Constant Bitrate dingofarmer's Avatar
    Oct 2004
    colorado
    I'v noticed that there are several custom radio kits for double din setups on crutchfields website, looks like it would be possible to modify the surrounding plastic to accept a lilli, cool thing is that it would mount up to the OEM mount points.
  8. #58
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    can you help us out with a link?
    DICE Los Angeles
  9. #59
    Oct 2004
    colorado
    Yeah, but i just purchased a peice of Plastic sheet 1/8th thinck from cartoys for about ten buck, I'm going to make the trim piece with it, plus it has a texture similar to OEM plastic.
    http://www.crutchfield.com/S-rLOQ4wT...g=112200&avf=N
    http://www.cardomain.com/shoplist~t~Laminates
    http://www.cardomain.com/item/SOUIECABS18
    Since most Double Din's are just a bit larger than 7" this may be an alternative to BObdo/fibre/and all that sanding.
  10. #60
    Oct 2004
    colorado
    Here are some pics of the one I made from the plastic sheet. Sorry about the quality, still not sanded or painted yet.
    http://www.geocities.com/dingofarmer/prelude3.html
    Drilled a small hole so I could use the remote.
  1. Replies: 35
    Last Post: 07-11-2006, 06:07 PM
  2. how about some help with making custom cases
    By Nav_Attack in forum General Hardware Discussion
    Last Post: 04-06-2004, 08:51 AM
  3. How to make custom bezels or cases?
    By WWE-TicK in forum Newbie
    Last Post: 03-22-2004, 03:12 AM
  4. Need A Custom Metal Case?
    By brentp4 in forum General Hardware Discussion
    Last Post: 11-12-2001, 09:19 PM
  5. Good things to use as custom cases!
    By brandondere in forum General MP3Car Discussion
    Last Post: 02-06-2001, 08:03 PM
