Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: started building amp/carputer rack
    Constant Bitrate JaxPt's Avatar
    Jan 2004
    since I have a PT cruiser with a pretty nice size cargo area in back, I decided to build a 3/4" MDF subfloor to house my amp/carputer. Heres some pics of the progress
    first I built a frame from 2x3"
    then test fit it in the cargo area before putting it together, looks good to me
    next a made a ghetto scribe to get the countour of the cargo area walls
    I traced the pattern to some posterboard and transfered it to my sheet of MDF
    Then I went to work with the jigsaw and cut my pattern, I then test fit it into the car
    I layed out my amp/carputer on top of the subfloor to give me a good idea of the area i would need underneath.
    My amp is going to be mounted under a sheet of plexiglass, and have a mirror base under it so I layed out the mirror and amp on a sheet of plywood that i'll use in between the base that i had previously made.
    The plexiglass is going to be lit by LEDS and have the www.ptcrew.com logo sandblasted into it. This will cause only the logo to light up when the led's are on. the entire subfloor will be covered in diamond plate aluminum as of right now anyway, but that could change.
    well thats all for now, I'll get back to the project in a few days and post pics of the progress
    2003 PT Cruiser
    Sony, DEI, Kicker, Polk Audio, Stinger sound system custom cold air intake, diamond plate floors, progress springs 2" drop
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
    Jan 2004
    when its done the floor of the trunk will have this effect
    and lit up
    2003 PT Cruiser
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    That's going to look very nice.
    ILL1
    Jan 2004
    Moving right along checked the area to mount the amp and carputer
    Cut out the plexi window area above the amp mounting area
    The carputer will stay hidden under the MDF floor except for the 2 80 mm fan holes that will be cut to mount the cooling fans above it
    Temporarily mounted the amp and test the fitment in the car
    thats it for today....
    2003 PT Cruiser
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
    Jul 2004
    Its lookin good but lemme ask u somin dont u worry bout da glass breakin ?? like if u hit a bump or maybe from too much bass?? just a thought
    Dec 2003
    Minnesota
    Quote Originally Posted by jay187
    Its plexiglass.. that won't happen (although it probably wouldn't happen with normal glass either).
    http://www.AJQuick.com/ - Fiberglassing Tutorials!
    My Cardomain Page - 1998 Dodge Neon R/T
    Jan 2004
    the mirror under the amp, well I'm not too concerned, its mirror tile and it'll be attached with spray adhesive and bolts throgh the corner, the same bolts that hold the amp in place. The amp is getting felt padding underneath to keep it from hitting the glass. it may or may not work, if it breaks oh well i'll replace it with mirrored blue acrylic sheet, which I may end up doing anyway
    2003 PT Cruiser
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
    Jul 2004
    O koo ya sorry i ment mirror insted of glass lolz but dats pretty good idea my cuzins dad has his own glass and mirror company down here so i might talk to him n get some of his strongest mirror and try this some time. also where are u gonna get the logo sandblasted i wanted to do the same but i havent found any where that has plexi around here so i havent even looked for any one dat dose custom sandblasting, good luck n keep post up dose pics
    Jan 2004
    You can get plexi at any home store, lowes, home depot, something like that.
    as far as sandblasting/etching . I should be able to find a good sign shop to do it pretty cheap, its a small piece. i just have to print the logo and get a negative made so they can blast it.
    the finished product should look something like
    only the grey area will actually be polished diamond plate aluminum
    2003 PT Cruiser
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
    Jan 2004
    It's alivvvvvvvvvve!
    Added my cooling fans today
    2003 PT Cruiser
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
  1. Warning... crazies ahead.
    By ddt in forum Off Topic
    Last Post: 05-11-2004, 11:06 PM
  2. start building my double bottom
    By BOND007BE in forum General MP3Car Discussion
    Last Post: 11-11-2003, 11:15 PM
  3. system layout configuration (amp rack) question
    By traitorhound in forum General Hardware Discussion
    Last Post: 06-18-2003, 12:24 AM
  4. Getting started
    By Xanxes in forum General Hardware Discussion
    Last Post: 02-17-2003, 11:39 PM
  5. Ya I have started building!
    By generalgman in forum General Hardware Discussion
    Last Post: 02-16-2001, 01:17 PM
