Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Where can I get a sheet of metal to create my own case?
  1. #21
    Constant Bitrate jaeger's Avatar
    Jul 2004
    Galveston Is., TX
    thanks guys...this really helps...
    i've located a couple machine shops around town...so i'm going to go and check those places and talk to the guys there
    this thread has been very helpful with all the suggestions...i hope other ppl benefit the way i have/will
    nine.
  2. #22
    Dec 2002
    Chico, Ca
    Ughh, just one note about the machine shops, they ain't cheap! Fifty to Eighty bucks an hour or so. Go pick their brain but don't expect to get anything made cheap. They will be happy to sell you the supplies however...
  3. #23
    Jul 2004
    Brazil
    If you can't bend the sheets, or if the bends don't look good, you can buy an "L" profile aluminum strip (I assume you will be using aluminum) to use at the joints, riveting the sheet metal to the profile with pop rivets. It even helps yielding an "industrial look"
    Anyway, that's how I am going to make my "case", but it will be mostly hidden under the passenger's side of the dash. I will use 2mm Al sheets.
  1. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  2. My case, create aux in
    By windalo in forum Car Audio
    Last Post: 07-06-2004, 05:58 PM
  3. Replies: 13
    Last Post: 05-13-2004, 06:30 PM
  4. Do we need a metal PC case or is plastic OK?
    By -al- in forum General Hardware Discussion
    Last Post: 09-17-2003, 11:27 AM
  5. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 10:42 PM
