Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Where can I get a sheet of metal to create my own case?
    Constant Bitrate jaeger's Avatar
    Jul 2004
    Galveston Is., TX
    i have been wondering where i can get some metal to encase my motherboard [only the motherboard]. I will bend it myself if i have to...
    my idea is that i don't want a full case...just something 3mm larger than the area/height of my mobo so i can protect it from dust.
    thanks
    nine.
    Nov 2003
    Annapolis Maryland
    I know Home Depot sells alumenum (sp) sheets. I think they are about 4'X4' or something like that. Not sure how much they are.
    Dec 2003
    South West, FL
    Quote Originally Posted by Animepix
    You may also want to check Lowes.
    Scorp
    Jul 2004
    Galveston Is., TX
    aluminum sheets, huh? tanx...and luckily for me, those two are right next to each other where i live
    nine.
    Dec 2002
    Chico, Ca
    Your basic welding shop will either have the sheets or send you in the right direction if the retail chains don't work out.
    When building the case keep in mind that a huge sheet will be wobbly (and thus your reaction is to go with thicker sheets) but when you start putting some bends in and cutting it down to size the metal it will stiffen. I ended up getting way to thick of metal, sure my case is built like a tank but it also weighs more then it has to and was a pain in the butt to fabricate.
    Jul 2004
    Galveston Is., TX
    thanks adamis...
    i'll make sure i don't get metal that isn't too heavy...i'm looking for something that is very light, and still durable...i just want something to surround my mobo...[the components will be elsewhere.]
    how did you bend it? i'm looking to get a rounded bend, similar to the cubit
    just not so tall
    nine.
    Jul 2004
    any luck
    So were you able to make what you wanted???? I want something like the cubit but a little smaller too.
    Jul 2004
    Galveston Is., TX
    i just posted today, silly.
    nine.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by jaeger
    What, 2 hours isn't enough?
    Jul 2004
    Galveston Is., TX
    Quote Originally Posted by Rob Withey
    so does anyone have any ideas on how i can get the round edges? [i was thinking of using a pipe and bending it, but there has to be a more surefire way]
    i have the sheetmetal, though...was that fast enuf?
    nine.
  1. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  2. My case, create aux in
    By windalo in forum Car Audio
    Last Post: 07-06-2004, 05:58 PM
  3. Replies: 13
    Last Post: 05-13-2004, 06:30 PM
  4. Do we need a metal PC case or is plastic OK?
    By -al- in forum General Hardware Discussion
    Last Post: 09-17-2003, 11:27 AM
  5. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 10:42 PM
