You liked the nissan panel i made that looks like carbon.....its not carbon,it just looks carbon,i used a carbon film with a hairdryer to shrink it over the panel after fabrication.![]()
Just incase you ask...i bought it in halfords.
Does anyone have a step by step tutorial on finishing an interior part with Carbon Fibre? Not with decals, but stripping off the plastic skin and then re-covering it with Carbon Fibre? There are a couple of threads here about CF but nothing specific.
o/______\o
(oo_OO_oo)
[]o-----------o[]
'94 320i
You have to invest quite a bit of money to be able to do it. We do it at a friends shop. You will need the vaccuum pump, bags, rolls of fiber, resin, etc. If you don't already know how to do it, it's easier to pay someone, since it's expensive to learn to do it.
and if you dont have connections be prepared to lay down some $$ for having this done. its not cheep either way.Originally Posted by David88vert
That sticker is a decent idea but does it look like it is a sticker placed on the dash or does it actually look like someone took the time to do the actual work to it?
Really depends on how well the sticker is applied as well. I've seen some work that is horrible and later some that I couldnt even tell the difference at all.Originally Posted by Scorpnstail
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Lilliput 7" Touchscreen
Mazda 6 Carputter > Click Me!
http://www.mashie.org/guides/cfbalsa01.html
It will be a little different for your application but this is how it's done
If you're recovering another peice... sand it or body fill it smooth, then make an exact opposite contour. So you can mate the two peices... Then follow his design. I would suggest practicing a little before getting right to it. Try a flat peice, then something more complex. Wraping weave around something sometimes it doesn't wrap evenly... and makes some ugly imperfections.
I was thinking about different options when I was looking at redoing my Pinto and thought about making all new CF molding where the old green plastic used to be.
Great post. It gives the basics on how to work with carbon fibre.
I would like to know how you work with a peice that has curves and angles and circular cutouts.
I edited it to help.
As for different shapes/cutouts... you'd actually want to 'glass over it and then cut it out with a dremel tool or somehow stretch the fabric as you lay it on. I would suggest placing it at that point then moving outwards. So only that spot is pulled the rest should be even.
GuyS!!! Take a look here..
http://www.icancomposites.com/forum/...3c08c83da2f400
It's a rather new forum. The guy describes how you can strip The "skin" off of a eg. Console, soak a piece of CF in resin/hardener, then lay it on top of the piece. Of course it's not that simple but, take a look here. If you go through the threads, it looks feasible - not molding a piece but covering a piece..
That mashie site describes a really similar method... It's possible guys!!
Who will get the first steps documented here ????![]()
o/______\o
(oo_OO_oo)
[]o-----------o[]
'94 320i
wow, those are great sites, LowMileLude double thanks, I like the servo contol off of your link too
[COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
