Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Foam to use as a base in fiberglassing, bondo work, etc.
    Jan 2004
    Hi guys, so I'm just about ready to get my project underway (molding the lcd into the dash) along with various other things that require fiberglassing, bondo, etc. and I've read that 2-part expanding construction or 2-part expanding packing foam can be used as a base for applying resin/fiberglass over. I was wondering if as an alternative to these foams if I could just use plain old styrofoam. My guess is, the resin will eat right through it, but has anyone actually ever tried this? Can you tell me for certain that it won't work and that the styrofoam will melt? If it is possible to use styrofoam this would be ideal as it is dirt cheap, easy to shave/shape, can be bought in about any shape imaginable, and if I wanted to get real creative, like molding a face into something, I could just buy a styrofoam dummy head and fiberglass it in. Just wondering about this, thanks for the knowledge.
    -DK
    EDIT: Okay so I've woken up to reality and realized that of course the resin will melt the styrofoam... much like gasoline will.. my question now is, can you recommend anything that will sufficiently protect the styrofoam from the resin but will maintain it's shape? Like some sort of spray on coating that would dry evenly but not be too thick?
    2002 Subaru WRX - Silver
    -FP18G turbo
    -Walbro fuel pump
    -Modified OEM 840 CC Injectors
    -TurboXS: UTEC, turboback, uppipe, intake
    -Blitz FMIC
    -STI cluster
    -17"x7.5" SSR Competitions
    -Tein Flex coilovers
    -NOS 50 shot
    -2004 rear conversion
    Jul 2004
    good ol aluminum foil should work if u cover up da strofoam good neva tryed it tho
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    Some 2 part foams can handle the resin just fine. Check www.shopmaninc.com. The have good prices and can answer your questions if you call them.
    Constant Bitrate aleromaster's Avatar
    Nov 2003
    Valrico, FL
    Floral foam. That works great
    2002 Oldsmobile Alero GL2 4DR
    Aleroputer 90% done (ripped out and being rewired)
    MYMODS:
    Pioneer Head unit in a remote location, Clarion Amp, XM Satilite Radio, 2 10" Audiobahn DVC Subs wired 1 ohm in a bandpass box, Grill Mesh, Halo Guages
    Jan 2004
    Hmmmm.. yeah I've heard that floral foam works too... interesting. Thanks for the tips guys.
    -FP18G turbo
    -Walbro fuel pump
    -Blitz FMIC
    -STI cluster
    -NOS 50 shot
    Constant Bitrate JaxPt's Avatar
    Jan 2004
    yep floral foam and then cover it with foil, tape, combo of both, just something to keep the resin from eating the foam
    2003 PT Cruiser
    Sony, DEI, Kicker, Polk Audio, Stinger sound system custom cold air intake, diamond plate floors, progress springs 2" drop
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
    Jun 2004
    Bay Area, California
    ive used standard styrofoam and the resin didnt eat it at all.
    I coated a styrofoam ball purchased at a hobby shop with fiberglass. no problems.
    Jan 2004
    Quote Originally Posted by WhiteRabbit
    woah, are you serious? can you tell me what exactly what kind of resin you used? Did you use the cheap styrofoam from like stereo packaging?
    -FP18G turbo
    -Walbro fuel pump
    -Blitz FMIC
    -STI cluster
    -NOS 50 shot
    yess please tell me more interested in this floral foam too - was it easy to use ??
    Jun 2004
    no, not like polystyrene expanding balls
    I have a feeling it wont eat those, but I have no experience with those, i really dont know. my gut says no.
    I was using standard polyester resin, and the styrofoam you find at hobby shops in blocks. or balls, as in my case. or cylinders....or heart shapes.... you know, that hobby styrofoam. the kind that looks like polyurethane 2 part expanding foam, rather than like a billion little balls expanded into a mold to form a shape of something.
  1. clay and fiberglassing
    By zerosiggls in forum Fabrication
    Last Post: 07-12-2004, 10:54 PM
  2. Disaster! aka, Adventures in Fiberglassing
    By Chairboy in forum General MP3Car Discussion
    Last Post: 04-12-2004, 01:02 AM
  3. Before you use foam to mount your Touch Screen
    By NewTechFool in forum LCD/Display
    Last Post: 03-05-2004, 01:33 PM
  4. Thanks to you guys, i've done some bondo work...
    By amrit50 in forum General Hardware Discussion
    Last Post: 02-24-2004, 09:07 AM
  5. Fiberglass over foam?
    By gork in forum General MP3Car Discussion
    Last Post: 08-20-2003, 05:57 AM
