Results 1 to 8 of 8
Thread: Problems with bubbles in the finish
    Oct 2003
    Copenhagen, Denmark
    Hey there
    I have been using bondo to make my screen appear stock in my dash and it is looking sorta fine now, i used some spray varnish with less gloss than usual. even though i use grit 600 sanding paper i still get some bubbles (well holes is more precise), what could cause this ? is it the weather, it is quite humid here in denmark and i was thinking that it might have some say in the final finish ?
    Jan
    Not doing carpc anymore
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    How much hardener are you using? Too much maybe?
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
    Oct 2003
    Copenhagen, Denmark
    Hmm, like it says on the box, about half an inch shorter lane of hardener as the putty.
    don't think thats it. And i only noticed it lately, usually its not a problem, but i thought as the weather has gotten increasingly hotter and more humid that it could make i difference.
    Jan
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    spray it really far away... in a fine mist like 15" away. that helped me.
    CarPC install is starting to come along again...
    Oct 2003
    Copenhagen, Denmark
    Thanks, I'll try that
    Low Bitrate ste1806's Avatar
    Nov 2003
    derbyshire u.k
    i think you will find it is air bubbles in the filler, and the way i over come these was to use a filler primer and then sand that filled in the tiny holes then did my top coat, hth.
    are the holes in the paint or in the bondo? I've allways found that to get the best finish on bondo I needed to use a layer of spot putty. It's like bodno but premixed and much finer. Good for finish work. You may want to see about picking some up.
    May 2004
    Arkansas
    Quote Originally Posted by ste1806
    MAKE SURE ITS NOT LAQUER BASED! IT SCREWED ME OVER WHEN I PAINTED OVER IT. THE PAINT WONT STICK! ok no caps now, but seriously use "Bulldog Adhesion Promoter" over the bondo first so it'll stick and don't use any laquer based primer.
    Quote Originally Posted by CFlux
    This is what I do, I agree 100% Its the Orange tube for bondo.
  1. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 04:37 PM
  2. Setup nearing completion, having all kinds of problems (yeah i did a :search:)
    By therussman2002 in forum General Hardware Discussion
    Last Post: 06-21-2004, 07:09 PM
  3. How I fixed my lilliput touchscreen problems
    By gubon13 in forum Input Devices
    Last Post: 05-22-2004, 07:21 AM
  4. Problems, Problems. Need some support.
    By mhermann in forum General Hardware Discussion
    Last Post: 04-22-2004, 08:59 AM
  5. Power Problems Please Look
    By kmfdmk in forum General Hardware Discussion
    Last Post: 02-15-2004, 09:39 PM
