Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: I have two pieces of aluminum metal. how do i bond them?
  1. #11
    Jul 2004
    Central NY
    Quote Originally Posted by BigRedBee
    JB Weld
    Yep that was going to be my suggestion. You can pick this stuff up at pretty much any department, home improvement or auto supply store. It's cool stuff, it's kind of like an epoxy (except no mixing) and it dries as a metal basically, you can sand it too. You wouldn't want to use it to make anything that is acting as a structural member in anything but I've seen/heard you can actually get by with it in situations you really shouldn't. Anyway good luck.
  2. #12
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    Quote Originally Posted by *alias
    you do have to mix jb weld. theres the welding agent and the hardening agent.
    rebuilding carpc... kinda..
  3. #13
    FLAC Chairboy's Avatar
    Jan 2004
    Cheap, strong solution: Take the pieces to a metal shop and pay them $10 to weld it for you. That way you don't need to buy a TiG welder, don't have to play with JBWeld (which, while neat, isn't great for strength), and you'll keep a good custom look.
    They'll probably do it real cheap, maybe even an auto shop can do it.
  4. #14
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    Quote Originally Posted by johnnyutah36
    Ill tell you what, ITS ALL ABOUT THE DUCK TAPE!
    That's the one!
  5. #15
    Dec 2003
    South West, FL
    JBwield is a great product , but if the piece will have to hold any weight at all you are better finding a different solution.
  6. #16
    Jan 2003
    Ruston, LA
    Rivets, or bolts and lock washers/nuts.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  7. #17
    Raw Wave
    Jun 2003
    Why cant you just use nuts and bolts?
    Much stronger, no need for any special equipments.
    Most pop-rivets are aluminium they easily shear off.
    If strength is not a problem even superglue can do the job well...depend on how much surface area you can glue. Otherwise as been mentioned use epoxy, JB weld, araldite and so on.
  8. #18
    Nov 2003
    Annapolis Maryland
    bubble gum and a paperclip Sorry, had to go McGyver on ya.
  9. #19
    Raw Wave
    Jun 2003
    The Blue Peter does a better job. Pritt stick and blue-tack
  10. #20
  1. aluminum welding/brazing/soldering??
    By wompser in forum General MP3Car Discussion
    Last Post: 09-07-2005, 12:07 AM
  2. VB help needed - DVDplayer- Brushed metal
    By Custommx3 in forum MediaCar
    Last Post: 06-11-2004, 02:03 AM
  3. Do we need a metal PC case or is plastic OK?
    By -al- in forum General Hardware Discussion
    Last Post: 09-17-2003, 11:27 AM
  4. No metal Case
    By nolmscheid in forum General Hardware Discussion
    Last Post: 03-12-2002, 12:47 AM
