Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: I have two pieces of aluminum metal. how do i bond them?
    Constant Bitrate jaeger's Avatar
    Jul 2004
    Galveston Is., TX
    so uh, i'm making this metal bracket, see? and i need to know how to make these two pieces that i have stick together permanent-like, see? and i need one of you geniuses to advise me on which type of solder i need, see? and what kind of iron i need...see?
    ok, enough of that. i just need to know if i actually need a soldering iron to do this, and if i do, what kind of iron and what kind of solder? or is there some sort of bonding magical stuff that will suffice?
    i am creating a bracket for my motherboard [and components] that will sit inside the dash, where my HU used to be.
    nine.
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    The only thing that I would know to use would be rivets. I don't think you can solder aluminum, only weld.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Ya rivets sounds good, I hear welding aluminum is tricky. At least more tricky than steel.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Jul 2004
    Ill tell you what, ITS ALL ABOUT THE DUCK TAPE!
    Low Bitrate savante's Avatar
    Jul 2004
    Chicago
    Quote Originally Posted by jaeger
    Solder is definitely not the best choice for structural useage (holding together two pieces of metal) its really only use is electrically (holding two spliced wires together, a wire to a PCB...).
    I think what Ill1 and Pudge said with the rivets is your best choice. Although you could spot weld them to kind of 'tack' them together depending on the strength of support you will need. Not easy but not as hard as welding two pieces of aluminum together with a nice looking seam.
    Jul 2004
    Galveston Is., TX
    hmmmz...rivets, huh? i'll try that...
    nine.
    Jun 2004
    Woodbridge, VA
    To my knowledge, an aluminum welder is $$$ and probably isn't the way to go. You can cut and bend a piece of sheet metal into the bracket shape that you want. That would be the way I would take care of it now that I think about it. You just might have to sit down and figure out where to cut and fold a 2D sheet into a 3D bracket.
    Feb 2004
    NYC
    Use stuff like hot glue or eproxy, wrapped in tape.
    Jul 2004
    Galveston Is., TX
    well see - this is what i do have - 1 aluminum sheet [12*36 in] a pre-made bracket [composition unknown] and an already bent-to-my-liking piece of metal [composition unkown]. What's cool is that i found these pieces and i have fashioned an enclosure for my mobo. the pieces fit together like a dream...it's just a matter of fastening them securely.
    nine.
    Newbie BigRedBee's Avatar
    Jan 2004
    PDX
    JB Weld
    VIA EPIA M10000 | 7" Lilliput Touch VGA | PW70 | 256 Meg RAM | 20 Gig 2.5" drive
    Dual Battery with Optima Yellowtop | Hellroaring Battery Isolater
    ICOM 2720A| Delorme Earthmate GPS | Tiny Track APRS
    Survives Crank
  1. aluminum welding/brazing/soldering??
    By wompser in forum General MP3Car Discussion
    Last Post: 09-07-2005, 12:07 AM
  2. VB help needed - DVDplayer- Brushed metal
    By Custommx3 in forum MediaCar
    Last Post: 06-11-2004, 02:03 AM
  3. Do we need a metal PC case or is plastic OK?
    By -al- in forum General Hardware Discussion
    Last Post: 09-17-2003, 11:27 AM
  4. No metal Case
    By nolmscheid in forum General Hardware Discussion
    Last Post: 03-12-2002, 12:47 AM
