Results 1 to 5 of 5
Thread: First Post.....and First Problem :)
    Aug 2004
    Well first off I have been lurking for a while and must say that you all know your stuff!
    I tried my first glass project today and am stuck on something.
    I am building a sub box to fit in the trunk of my Acura TL-S.
    I used the blue tape, tin foil......then I put 2 layers of glass on. It went fine, no problems....
    When it was dry, I went to take it out......and it came right out!!! The problem is that so did the tape and tin foil. So I started to try to get the tape and foil off and can only get about 1/2 off. The rest seems to just be stuck. I have tried knives, xacto, etc.
    Since I am planning on carpeting the box...should I even worry about it?
    Just keep building the box on the inside?
    DTT
    Jan 2003
    Ruston, LA
    If nobody is going to see the foil, why worry ?
    [TOMA]And for next time, I believe you can coat the foil with wax.[/TOMA]
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by DeathtoToasters
    DTT
    Why do you want to kill toasters? I enjoy toast in the morning. Couldn't do that without my toaster
    Installed.
    -GPSSecure- - GPS Tracking
    Aug 2004
    Quote Originally Posted by brady
    I cannot answer that....you don't want to know the answer...you cannot handle the answer.
    The future is not set. There is no fate but the one we make......S.C.
    Newbie Redmachine's Avatar
    Jul 2004
    Katy, Texas
    It happens to everyone, just peel as much off as you can. If there is some left oh well, Its covered.
    BTW this happened to mine.
  1. First Post: To get Touchscreen or Not?
    By FunK in forum Newbie
    Last Post: 10-31-2003, 12:36 AM
  2. Newbie's First Post - Lots of Questions!
    By Louis M in forum LCD/Display
    Last Post: 08-20-2002, 11:20 PM
  3. First Post
    By Rob in forum Off Topic
    Last Post: 04-22-2002, 04:01 PM
  4. FIRST POST OF THE NEW YEAR
    By lstrunk in forum Off Topic
    Last Post: 01-01-2002, 01:44 AM
  5. First post in 2000
    By psalmx in forum General Hardware Discussion
    Last Post: 01-01-2000, 11:39 AM
