Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: First Fiberglass Project....have questions...
  1. #11
    Newbie Redmachine's Avatar
    Jul 2004
    Katy, Texas
    I completed my first FG project about 2 weeks ago, I had a few air bubbles, What I did was wait for every thing to harden , drill a hole, or grind the top off of the bubble and fill it with resin, I know too much resin can make it weak, but it works. Also, I discovered that There are different weights of FG mat. Next time I'm using 6 oz instead of wal mart bondo mat that weighs in at a heafty 1/2 oz .
    I used chris's web site alot, that guy is great
  2. #12
    Aug 2004
    Where aer you going to get your mat next time? I have been getting mine at Home Depot along iwth my resin. Funny thing is they don't carry any extra hardener. Oh Well.
    I am adding one more later then going to drill the small holes and fill in with some resin.
    Then hopefully if the kids dont bug me too much, I wil be able to cut it to shape today.
    I will post pics when I am done. Not that anyone here needs them
    The future is not set. There is no fate but the one we make......S.C.
  3. #13
    Jan 2004
    really? Both of my two local homdepots carry extra hardener.. just above the 1 gallon cans. If you really need hardener, see if you have another homdepot in the area, they may have it.
  4. #14
    Aug 2004
    Well I live 20 miles form the nearest home depot. The next one that is close if over 35 miles away
    Well I drilled holes in the larger air pockets. What I did was the following:
    I drilled all the holes first. Then I stuffed little pieces of mat in the holes with a small stick. Then I poured resin, then a bit more mat. I used that pattern until the whole was stuffed.
    It only took a few min. The holes/air pockets are now the dark resin look that the rest of the box has.
    I know that is not as good as originally doing it correctly.....but I am sure it is a step up from leaving the air pockets
    Now I will wait about an hour, then fit it back in the car and mark the final shape. Then out comes the dremel!
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 04:30 PM
  2. My Project Outline w/some Questions.
    By celicagtsblak in forum Newbie
    Last Post: 06-10-2004, 11:39 PM
  3. starting my first carputer project, have some questions
    By ssa_whiskey in forum General Hardware Discussion
    Last Post: 02-24-2004, 03:43 PM
  4. New to the board, project questions!
    By smeagol in forum General MP3Car Discussion
    Last Post: 03-14-2003, 09:58 AM
  5. starting project soon, questions..
    By tekknikal in forum General Hardware Discussion
    Last Post: 05-28-2002, 07:47 PM
