Results 1 to 10 of 14
Thread: First Fiberglass Project....have questions...
    Aug 2004
    Well,
    I made the form for my sub box. Everything went fine.
    Now I am building it up and finding that I am getting several air bubbles. Should I just leave them. They do NOT flex at all and are very solid, but you can tell it is a bubble.
    I don't care if it looks ugly as I am going to carpet it.
    Another question is this..... I have done 5 layers already. The box only flexes on the ends where it is thinner (the ends that I will be cutting off)
    I have stood on it and it has not given in at all.
    How many layers is enough? It is going to house a 10" sub.
    Thanks for the advice.
    The future is not set. There is no fate but the one we make......S.C.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    I did this as my first project as well. I'm finding out that because of the air bubbles, the back leaks a bit. Before you get too much farther, fill the thing up with water (make sure everything is completely set) and fill holes. I'd say 5-6 back layers should be fine. I think i had like 7 or something, and hey I'm pudge and it didn't flex.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    the air bubbles will make the enclosure more weak. if its just a single sub you might be ok..but if you have any leftover fiberglass resin you might as well use it...
    rebuilding carpc... kinda..
    Jan 2004
    Jersey/NY
    yeah what pudge said about the leaking... also for future reference, smaller pieces of fiberglass matt help to reduce air bubbles. Those huge pieces you (or me at least...) use cause we're lazy are what get the air bubbles usually.
    Oh and I'd say 6 layers.. 5 is probably enough, but just do 6.
    good luck.
    Aug 2004
    Quote Originally Posted by Pudge
    So let me make sure I understand this.....fill the thing with water and see if any leaks out?
    If yes....full in the holes obviously. If not...then I am ok?
    I was thinking of doing another layer, which would make 6, then after it dries, drilling a small hole into the air bubbles and pouring resin (obviously mixed with hardener) into the pockets....that would fill them up.
    Is that overkill?
    Thanks for the prompt responses.
    Aug 2004
    Quote Originally Posted by wizawuza
    good luck.
    Yeah I realized that about the bigger pieces.......
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Probably not overkill, go ahead and get your 6th layer on there before you test.
    2 Kicker Comp 10"
    Check it out?!
    Aug 2004
    Ok...sounds good. I will keep you posted.
    Constant Bitrate JaxPt's Avatar
    Jan 2004
    2003 PT Cruiser
    Sony, DEI, Kicker, Polk Audio, Stinger sound system custom cold air intake, diamond plate floors, progress springs 2" drop
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
    Aug 2004
    Quote Originally Posted by JaxPt
    That is what I have been using
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 03:30 PM
  2. My Project Outline w/some Questions.
    By celicagtsblak in forum Newbie
    Last Post: 06-10-2004, 10:39 PM
  3. starting my first carputer project, have some questions
    By ssa_whiskey in forum General Hardware Discussion
    Last Post: 02-24-2004, 02:43 PM
  4. New to the board, project questions!
    By smeagol in forum General MP3Car Discussion
    Last Post: 03-14-2003, 08:58 AM
  5. starting project soon, questions..
    By tekknikal in forum General Hardware Discussion
    Last Post: 05-28-2002, 06:47 PM
