Results 1 to 10 of 14
Thread: Bondo question.
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Bondo question.
    Hey guys I started to intall my screen into my center cosole. I'm using the the glass reinforced bondo to make a frame for the screen. I made it yesterday and waited until today to continue work on it. When I went to begin sanding it, the bondo was still kind of sticky to the touch. Is it suppose to be this way or should it be hard and not sticky? I'm thinking I didn't add enough hardner. What do you guys think might be the problem? Should I wait longer until it is no longer sticky?
    Thanks for the help.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    More hardener. Regular Bondo should be dry within 5-10 min and workable in 15-20 depending on how much hardener you use. I have never worked with the glass bondo but i would assume that is similar
    Dec 2003
    New York
    Will the frame I have become non-sticky with more time or will I have to start over again?
    Installed
    Aug 2003
    Moncks Corner, South Carolina
    My guess is you didn't mix enough hardener to begin with, it will harden but it will take more time than it would have normally.
    Mar 2004
    Bay Area, CA
    Quote Originally Posted by Quattro-A4
    I used the regular bondo but Mine was tacky too(even after a day). Maybe I did it wrong but after sanding off the first tacky layer, it turned out fine. Granted, it might be due to dust adhering to the bondo.
    Dec 2003
    New York
    What color should the bondo be after I have mixed the hardner into it?
    Installed
    Jan 2004
    Jersey/NY
    Yeah my guess is to wait.. At worst, it won't dry up, and you'll have to start over. At best, it'll become dry, and you'll be done with that layer.
    Jan 2004
    California
    I would be to immpatient and scrape the tacky stuff off. Bondo should dry quite quickly usually to quick. The color depends on the type of bondo
    Dec 2003
    New York
    So I couldn't wait for it to dry any longer. I started to sand the frame and as I got the top layer off it wasn't tacky anymore.
    Installed
    Jul 2004
    Ohio
    You guys don't heat cure it? Force it to dry faster by using a hair dryer or heat lamp...?
    I know that's what we'd do if it was fiberglass that's not cured all the way yet.
    Glad to hear you were able to sand off the tacky part.
  1. bondo question??
    By boomboom in forum Fabrication
    Last Post: 07-19-2004, 08:58 PM
  2. Dumb question, MP3 storage?
    By judoGTI in forum FrodoPlayer
    Last Post: 07-04-2004, 09:37 AM
  3. DVD drive question
    By Pokey in forum Newbie
    Last Post: 05-11-2004, 04:26 PM
  4. fiberglass or bondo??
    By faiz_23 in forum Fabrication
    Last Post: 05-04-2004, 06:39 AM
  5. lcd power question
    By jrbless in forum LCD/Display
    Last Post: 04-07-2002, 12:27 PM
