Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 46
Thread: Volvo S60 in-dash project
  1. #11
    S80
    S80 is offline
    Newbie S80's Avatar
    Aug 2004
    Örnsköldsvik, Sweden
    Nice!
    Very nice!
    I'm about to do my first install in my Volvo S80, but I’m not going to do an "in dash" installation at this moment.
    I'm wondering how you have mounted the PC in the trunk (Since S60 and S80 are basically the same design) Do you have any pictures?
    /Niklas, Sweden
  2. #12
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Hey S80,
    I haven't mounted the 'puter yet, but I will make a small case (mini-itx) that has only one connector on the outside (old scsi 50p connector). That way I will be able to take it out very easely.
    When I have some results, I will post pics here.
    Joa
    P.S. Nice car, the S80 btw
  3. #13
    S80
    S80 is offline
    Newbie S80's Avatar
    Aug 2004
    Quote Originally Posted by JC-S60
    Hey S80,
    Ok. That sounds like a clever solution... I have to think about something similar!
    indeed! But the S60 is kind of sportier
    /Niklas
  4. #14
    Jun 2004
    Malmö/Sweden
    Your installation so far looks awesome S60!
    I'm about to install the Puter in my C70. I'm still waiting for some parts for it. I haven't decided if I should go for an "in dash" installation yet either. But I just got to go to my dealer and see if I can get that 2din Panel for my C70 aswell.
    /Kalle
    Progress Meter [||||||||||]
    I Have: Epia M10000, 40gb 2,5HDD, 512mb Ram, 2,5" Slimline CDRW/DVD Combo, Inside a Morex 3688. USB GPS Mouse.
    I Need: USB Fm Radio, USB 2.0 Hubb, Wiring
  5. #15
    Mar 2004
    Ghent - Belgium
    That C70 certainly is a nice car too!
    I hope you can find the panel, as it is really helpful if you want to keep it simple and still have a factory look.
    To all VOLVO drivers: what audio-system do you use now/going to use with the 'puter ?
    I will be using the factory amp (4x 75w) + speakers (4x 3 way + 1 center in the dash) + an amp for the center speaker (30w max, I guess) and one for an additional sub. This way I can have 5.1 sound
  6. #16
    Constant Bitrate dexy's Avatar
    Jul 2004
    NY
    neat setup, how did you fry your xenarc. Hope you correct it, so that you don't fry the next one, or your comp. Also put inline fuses on your power lines, they save the day.
    2 thumbs up to that fabrication. It looks really OEM. did you do that with fiberglass/bondo too? i.e like the BMW one?
  7. #17
    Mar 2004
    Ghent - Belgium
    Well, I used an 2din adapter that was available from volvo and that fits very nicely in the dash (instead of the HU803 dolby pro logic head-unit from volvo) and cut my xenarc to fit in the 2din space.
    Then I filled up the gaps with "body filler" (which you guys call bondo, I guess). I needed about 5-6 layers to get a nice surface and form and another 10 layers of paint (with wet 600 sanding inbetween) to have a result I liked.
    The colors do not seem that different as they look like in the pictures.
    The xenarc was just reverse polarized, so the fuse didn't help anyway. Plain stupidity, after 5 hours of working on the car, I didn't check the polarity of the power plug before I plugged it
  8. #18
    Jun 2004
    Malmö/Sweden
    I don't know what amp to use yet, Thats the next thing I'm going to get.
    I guess I'll figure that out next week when I get back to work!
  9. #19
    Mar 2004
    Ghent - Belgium
    If you're interested, I can give you the pinout on the stock amplifier (is you have one, it is located under the passenger seat). It looks like this:
  10. #20
    Jun 2004
    Malmö/Sweden
    Talking
    I never thought of that before, I was just out and looked. I have an amplifier under the passangers seat but It's quite smaller than yours. And it doesn't have that metall/plastic casing.
    Wonder of it would be the same pinout? =)
    PS: I don't have the center speaker that you have in the middle of the front dash. There are 3 Sound systems. Basic/Normal/Advanced, I have the Normal one. (Not sure they are called this, just to illustrate my point=)
  1. prototype at work Volvo s60 D5 Intel P4
    By hklomann in forum Show off your project
    Last Post: 02-26-2005, 11:54 AM
  2. New Project: Contrast Mediaplayer
    By pplante in forum Software & Software Development
    Last Post: 07-07-2004, 12:06 PM
  3. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
  4. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
  5. My project for the day - advice needed
    By ddt in forum General MP3Car Discussion
    Last Post: 12-02-2002, 08:51 AM
