Results 1 to 10 of 12
Thread: Buttonless Lilliputs
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    I want to install my lilliput without any buttons. Beyond doing the auto-on mod, what else would I want to do to the screen to make it so I don't need to push any buttons on it?
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    if going buttonless make sure the infra red eye is still usable, there are times when you need to "set some screen parameters"
    the infra red eye is pretty easy to desolder from the buttons pcb, which must still be connected to the screen but can be left dangling inside the housing, I used an audio cable from a cd rom to extend the infra red eye on my buttonless setup
    good luck
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Feb 2004
    Spokane, WA, US
    you're right. I forgot about the remote.
    Constant Bitrate hussein's Avatar
    Sep 2003
    AB, CANADA
    i covered up all my buttons and just left the infared beam hole. its way cleaner wtihout the buttons...
    kinda lost the little covering thing for the infared hole, gotta find it, haha.
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    If you do the auto-power on mod, this would work great - no need for any buttons, though making a window for the IR sensor is a good idea. I used part of an RJ45 jack to make a window in the bezel I made for the Lilly - works great and looks pretty good
    Banned eatyummypuppies's Avatar
    Feb 2004
    li, ny
    I made an extension for the power button so I can turn off the lilli a few blocks before I park (also with the coyote mod). I used a tiny bush button from Radioshack that just happened to match my dash perfectly, rendering the button completely invisible. This, I think, is just as important as concealing your screen.
    Also, I don't even have the IR sensor visible. I was planning on drilling a small hole for it or something, but it turns out that I never use the remote anyway.
    Any idea on how to make a sliding door or some other device to be able to conceal the screen?
    Jun 2004
    Queens, New York
    using an actuator or a low geared motor and some sliding tracks. http://www.selectproducts.com/frames.html
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Most of the good actuator I have seen are expensive. I'm tring to figure out how to do the samething. I'll let you guys know how I implemented when I get done with the cover/door.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Jun 2004
    Queens, New York
    i think an electric motor would work better for something like that... actuators are good for moving heavy stuff, an electric motor is fairly cheap, and would give that slow fluid movement that would look pimp.
  1. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  2. Droping the Right click box on lilliputs
    By Scorpnstail in forum LCD/Display
    Last Post: 06-23-2004, 04:50 PM
  3. Replies: 1
    Last Post: 02-06-2004, 05:44 PM
  4. Since no Lilliputs around
    By nodeel in forum LCD/Display
    Last Post: 12-02-2003, 12:44 AM
  5. VGA Lilliputs from EE on ebay price gone up?
    By divadiow in forum LCD/Display
    Last Post: 11-03-2003, 12:30 AM
