Results 1 to 9 of 9
Thread: Mitsu On-Dash Project
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    Ok guys I'm trying to figure out everything to make an addon dash panel on top of my current dash above the ac controls extending all the way to the passenger airbag cover... should be able to figure out where by the following pics...
    ok now I am planning to make this out of fiberglass... so what is the best way to attach fiberglass to plastic? also what is the best way to make a housing to hold the xenarc 700TS?
    Has anyone every done something like this or seen it done? any help is much appreciated
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    you are in luck, there is a fellow who used to be active on the forums, named Arby, and he too had an eclipse, and he decided to put an 8 or 9" lcd on his dash..
    his outdated website:
    http://arbytech.com/carmp3.php
    Nov 2002
    Vermont, yay.
    You'll want to rough up the plastic a bit (i.e. coarse sandpaper) before laying the fiberglass down.
    Jul 2004
    Tampa, FL
    Yes I've seen that Install before... and thats not what i want... here's a pic (greyed portion is where the addon dash will go) I want to addon to the current dash so i can mount my screen, buttons, and other controls in the added on portion of the dash
    Feb 2004
    Pittsburgh
    good luck with your project...i have a 96 eclipse and wanted to do something similar to your idea, but as it came along it REALLY was way to obtrusive looking and didnt look good at all. its hard to add on to the dash without disrupting the natural flow it has, so good luck and cant wait to see it
    Jul 2004
    Tampa, FL
    Yes i'll def keep you guys updated
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    I just finished the other day in my 4runner what sounds similer to what you want, is a dash pod kind of for your screen.
    I started with the head rest mount framed it with 1/2" x 1/4" trim wood covered it with a t-shirt covered in resin then fiberglass about 3 layers then bondo, sanded for a few days primed and painted.
    To get the dash shape I covered the dash in blue painters tape and held the pod in place and filled all the gaps then sanded, then I attached it to the dash with high strength double sided tape and its on their if I wiggle the pod the dash moves. Then i cut out the bottom so the air vents just point down now.
    It sounds like thats what you are thinking of just maybe a little more stream line shaped.
    you can see it here.
    http://www.cardomain.com/memberpage/661069/2
    Jul 2004
    Tampa, FL
    Yes that is the clostest thing Ive seen to what im trying to do... thanks for the pics
    Jul 2004
    Tampa, FL
    alright... my project is finally underway, im gonna keep posting pics as i get them step by step
  1. The Vectra CarPC / CarPuter Project v2
    By ccsnet in forum Show off your project
    Last Post: 08-29-2005, 06:46 PM
  2. New Project: Contrast Mediaplayer
    By pplante in forum Software & Software Development
    Last Post: 07-07-2004, 12:06 PM
  3. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
  4. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
