Results 1 to 3 of 3
Thread: Cheap Plastic case for Carputer
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    Talking Cheap Plastic case for Carputer
    Hey guys while at the hardware store looking for a case to hold my MB and all in the car i found this piece of tupperware
    Its actually decor which is a 4.75L plastic tub which really has the perfect size for all the parts i have
    I can easily install the MB (with ram), PSU and HDD into the case and have space left over.
    the way the case is made its not that thick and will hold the MB and everything else verticle a 3.5" hdd will fit in here nicely
    All id have to do is carpet the sucker to make it look good in the boot
    I am in australia but im sure this or something like it can be found easily i couldnt find it in the supermarkets only in the hardware store in homewares/storage
    So what do u think? $9 case its not bad
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Heh, nice. I have a similarly cased computer set up in my kitchen. Thought it would match the decor
    The one caveat with a plastic case like that is that it won't dissipate static electricity very well, and therefore charge can build up which could potentially damage something. I havn't had any problems on mine, but it's not in a moving vehicle either. It's probably unneccesary, but if you want to take it safe you should put grounding points around the case.
    Aug 2004
    Thats a good point i will look into that thanks
    I have used the metal plate and cut the plastic out so it just pops in and it looks great
    I will make some ground points to be on the safe side thanks for the tip
    The picture isnt very good iv got a crappy poloroid 2.0mp cam and it doesnt take pictures very well if there isnt any natural light around.
    The plate is centre i dont know why the pic showed it as crooked prob cause its on my bed when i took the pic
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  1. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  2. To case or not to case?
    By dummptyhummpty in forum General Hardware Discussion
    Last Post: 04-08-2004, 06:19 PM
  3. Plain black plastic case
    By lightman in forum General Hardware Discussion
    Last Post: 10-17-2003, 11:45 PM
  4. Do we need a metal PC case or is plastic OK?
    By -al- in forum General Hardware Discussion
    Last Post: 09-17-2003, 10:27 AM
  5. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 09:42 PM
