Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Single DIN mounting holes
  1. #11
    Falls Church, VA
    Those side holes are stock Toyota mounting holes. They are standard and can be found on almost every aftermarket radio. I do not have the figures to tell you the exact sizing, but you could hit Walmart, buy a cheap stereo, measure and return it.
  2. #12
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Looking at one of my pioneer units, sitting on a shelf above my desk :
    It has only 3 holes in the same place as the five you indicate (working from the left in your diagram) it has 2,3 and 4.
    3. and 4. are dead centre height wise (1" or 25mm from bottom)
    2. is 1 7/16" or 35mm from bottom
    Now from the front it is difficult. the pioneer fits into a cage. At the front there are two small lugs which stop the cage going forward (or the stereo back)
    from this the holes are:
    2. 7/8" or 22.5 mm
    3. 1 1/8" or 29 mm
    4. 3 1/4" or 83 mm
    Hope this is of some help.
    *note I have another stereo (Ford) sitting around somewhere, when I find taht I will measure that too.
  3. #13
    Jul 2004
    Minneapolis
    These are pictures from a Pioneer DEH-1600. The vehicles that use an ISO mount are all a little different that's why there are a few holes. If I get a vehicle in today that uses factory ISO brackets I'll take a picture to show you some more examples. Note that where I have the tape measure lined up isn't where you would normally line the deck up to the factory. It is just for reference. The front of the factory radio will usually line up with the front of the aftermarket deck when it's face is off. P.S. A Ford radio doesn't have ISO holes.
  4. #14
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Talking
    Your awesome christmaspie and enforcer, thanks!!!!!!!
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by christmaspie
    dammit! the festive foodstuff baked in a pastry shell is right, the ford stereo has no ISO holes.
  6. #16
    Jan 2004
    I finished the mounting bracket:
    http://g35driver.com/forums/showflat...sed&sb=5&part=
    Thanks everyone that contributed thier advice.
  7. #17
  8. #18
    Jan 2004
    Quote Originally Posted by god_of_cpu
    Do you have any pictures or links to such things?
    Sure the Empeg's sled does this.
  1. Help - Opinions on my DIY LCD case (single DIN)?
    By nxt125 in forum General Hardware Discussion
    Last Post: 04-14-2011, 09:28 AM
  2. Single din upside down (?)
    By LowMileLude in forum LCD/Display
    Last Post: 08-09-2004, 05:26 PM
  3. Mounting a screen in a DIN slit?
    By 850 Stylzz in forum LCD/Display
    Last Post: 03-07-2004, 12:47 AM
  4. has anyone fitted a carputer into a single din
    By bertybassett in forum General Hardware Discussion
    Last Post: 10-10-2003, 09:02 AM
