Results 1 to 10 of 14
Thread: Made fiberglass dash but looks like crap! PLZ HELP!
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    It took forever to finally get screen fiberglassed up then I bondo-glassed it and tried to make is smooth and all but it turned out to keep getting holes in it, and it might be smooth but it was wavy so it looked like crap. I some that M3's dash on here and it said that he used foam. Should I just go up to Home Depot and buy some expanding foam and carve that which would probably be alot easier than trying to sands and shape bondo-glass?
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I have been using reinforced glass bondo on my screen as well. I have found that if you smooth the bondo with you finger as it dries it will be much smoother when dried. After you have sanded it pretty well, then use regular bondo to fill in the holes. But use very light layers of the regular bondo, just enough to fill in the holes. Sand and repeat with bondo again to get a smoother finish. From what I have found, if you don't use light coats of the regular bondo, you will get holes just as before. And you will have to do a lot of sanding if you want to get a really smooth finish.
    Edit:
    My screen looked similar to your in the pictures, you just have to sand it more. I did alot of sanding on mine, got it pretty even before I used the regular bondo.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Low Bitrate microbionic's Avatar
    Aug 2004
    medina,ohio
    i filled in the holes with filberglass resin,, then sanded .. then all the holes where gone,, and it was mirror smooth
    Dec 2003
    Edmond, Oklahoma
    Quote Originally Posted by Quattro-A4
    Thanks for the tip. I was about to just say f'ck it and throw it into the trash. But I'll try out that bondo fill and see if that will do the trick.
    Dec 2003
    Edmond, Oklahoma
    How should I paint it to get a nice finish? Right now I'm using like primer mixed with black spray paint I don't think it looks good though. I want some texture.
    Variable Bitrate LanoX's Avatar
    Aug 2004
    Sydney
    what is bondo?? tnx sorry
    [|||||-----] 95% complete
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Quote Originally Posted by LanoX
    Bondo is a brand name of fiberglass/car body filler.
    Over here in the UK, we have P40/P38, which basically is the same thing, but different names
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Aug 2004
    Sydney
    Quote Originally Posted by Confused
    Garry
    aha okay i though it might be that what u told me but huh so many names there
    Newbie double dimes's Avatar
    Aug 2006
    Bondo is bad mmmka
    Garry
    Quote Originally Posted by LanoX View Post
    Ok here is the skinny on this and maybe I can clear up the confusion.
    Bondo is a brand name of body filler it is cheap and I don't recomend using it. It has the tendancy to shrink which will cause cracks and start to break apart.
    I would use Evercoat brand body filler it costs about 25-35 dollars a gallon and is very easy to work with.
    All body fillers are a blend of polyister and plastic
    Fiberglass body fillers such as Kitty Hair have strands of fiberglass in the mixture. They are used for filling small holes about the size of a dime or quarter. Or for reinforcing a molded in item lets say molded ground effects or hood scoops.
    For filling small pin holes I would use evercoat body filler mix up a small amount and use a little less hardner that way it stays in a more plyable state longer. There is also a product made by PPG that is called spot filler it is ideal for small pin holes and also can be used to fill rock chips on a hood if all your doing is repainting. This product is easy to use becasue it comes in a small tube and is already premixed.
    The best way to fill pin holes is to use a straight edge razoe blade for a spreader that way you are only applying the filler to the hole and a small area around it.
    If you have any questions let me know I did body work for a living for a few years and I do all my own custom work now.
    Hope this was helpful
    Jul 2006
    Springfield, IL
    Wow - talk about resurrecting a dead thread.
    "It's a blessing . . . and a curse."
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 04:30 PM
  2. Replies: 13
    Last Post: 06-02-2004, 07:12 PM
  3. Non-permanent fiberglass mount
    By Chairboy in forum General Hardware Discussion
    Last Post: 03-21-2004, 04:33 AM
