Results 1 to 8 of 8
Thread: Putty I can form and then harden?
    Falls Church, VA
    I am looking to make speaker pods for the corners of my dash (Shoved between the pillers/dash/winshield. The easiest way is to create a baffle and surround for the speakers, cover in non hardening clay and shove them into the corners. I could then sculpt them the way I want and carefully remove them. This is the tricky part... how do i go from here?
    I guess I would have to form a mold around them and then create new pods out of glass inside the mold. Seems like 3x the work...
    Is there a thick putty that i could form the pods with, carefully pull out and then coat on a hardener? Let that hardener soak in a few layers to make one nice hard outer shell? then i scoop out the putty that didnt harden from the inside and I'm good to go?
    Any advice?
    Constant Bitrate nirvanades's Avatar
    http://pasmag.com/gear/techtalk.asp?section=audio&ID=19
    Depends on how big your speakers are... but this is a good method! Good Luck and post pics if you do it.
    2003 Chevy Tahoe Z71
    STOLEN - M10000, 512MB, 60GB 2.5" HDD, 7" Custom mounted Lilliput, Morex 3688 Case, 90W PSU w/ ITPS, GPS & CD-RW/DVD. New parts ordered for the next generation!
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Nice tip
    TruckinMP3
    Read the FAQ!
    Jan 2003
    Ruston, LA
    puTTy
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    LOL - PuTTy ?
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    肚子笑痛了
    S60 Install
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    dang that is a nice tip. that looks awesome.
    Jan 2003
    Ruston, LA
    I couldn't stand it anymore !
    I had to fix it. I feel better now
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
