Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: How to mount laptop in trunk?
  1. #11
    Feb 2004
    Quote Originally Posted by ppgt94
    OK, scratch my idea. I just realized that if you set your notebook on the carpet it would probably sufficate its air flow. Check and see if there's a fan on the bottom of your notebook.
    I also have this Targus Chill Mat to help cooling:
  2. #12
    Constant Bitrate gutterslide's Avatar
    Jan 2004
    ATL
    you can put something to act as spacers between the laptop and the mounting board. you can find simple stick-on rubber feet anywhere.
    i have too much free time...
  3. #13
    Feb 2004
    Quote Originally Posted by gutterslide
    How and what would you use to make tha laptop stay in place on-top of the board?
    Also, how would you connect the quietfeet to the sub-box and the board to the quietfeet to stay in place during sharp turns?
    Btw, thanks for the visual image!
  4. #14
    Constant Bitrate blicky_1's Avatar
    Sep 2003
    North Hampshire, United Kingdom
    Thumbs up
    Is that a Jetta I see? My Carputer is held down with Velcro. It STAYS PUT. That **** is strong as hell on the factory carpeting. Just use he "grab" (coarse) side.
    I use the same, works for me!
  5. #15
    Jan 2004
    ATL
    Quote Originally Posted by phatrabbitzz
    a couple of cheap adjustable nylon belts, crossed, would hold it firmly in place.
    as far as attaching the feet securely enough for the road, that's a tough one. you can put screw in from the inside of the box, and from the top of the board, into the feet. a couple into each foot. you just can't put them too deep because the screws will transmit the vibration and i'm sure it would cancel some of the dampening.
    if you really wanna go crazy, you can use some RC car shocks.
  6. #16
    Feb 2004
    Do you have a link or pic of what those look like?
  7. #17
    Jan 2004
    ATL
    shocks
    suspension parts
    i don't know how you would actually implement it, though.
  8. #18
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    Why dont you just put it under your seat.You guys like to make thing hard for your self and then wonder why its not working out the way you thought or it gets broken in a week.
    2-15" ILO lcd w/DVI
    6800 gt Duel DVI out
    p4 1.6ghz flex atx board
    1gb 400 ram
    120gb(2-60gb raid) sata hd
    2-60gb hotswap
    WIN2K Pro SP2
    M.A.M.E. w/2,300 games
    CARPuter info
  9. #19
    Feb 2004
    CHUPACABRA, There isn't space under my seat.
    gutterslide, I'll pass on the RC suspension. I'm still trying to figure out how to mount these quietfeet to the sub-box.
  1. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 11:52 PM
  2. would a omni ceiling mount antenna work in my trunk?
    By aoLhaTer in forum Wireless Communications
    Last Post: 07-14-2004, 03:33 AM
  3. laptop mount for car
    By trd604 in forum General Hardware Discussion
    Last Post: 03-02-2004, 01:48 PM
  4. Signal Degradation with trunk mount PC?
    By S4Per in forum LCD/Display
    Last Post: 01-20-2004, 11:04 PM
  5. Where to buy a auto laptop mount?
    By GK in forum Off Topic
    Last Post: 11-21-2003, 02:12 PM
