Results 1 to 10 of 19
Thread: How to mount laptop in trunk?
    Feb 2004
    How do you guys mount the laptop in the trunk in a way that it doesn't slide in sharp turns or jumps in case of a pot-hole or two?
    I was thinking about mounting my laptop on-top of my sub-box (MDF), but I'm not sure what materials to use and how to keep it in place.
    Any ideas?
    TIA
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Do you think mounting you laptop on the sub box will be a good idea. I may be wrong, but that constant vibration from the subs will be nothing but trouble. I know laptop hard drives are designed to take a beating, but will it be able to survive this amount of abuse.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Maximum Bitrate MoFo's Avatar
    May 2004
    TX
    My laptop is ontop of a fanpad that I drilled onto a piece of masonite board. Under the masonite board is industrial strength velcro material. The Laptop is secured to the fanpad with a strip of nylon that velcro's from the bottom of the fanpad to the top of the laptop. I can take sharp turns at high speeds and the laptop doesnt budge
    Elsewhere
    Quote Originally Posted by MoFo
    Yes, but those are entirely different forces than the constant vibration of a subwoofer enclosure...
    How about the Wiki?
    Feb 2004
    Quote Originally Posted by Quattro-A4
    Do you think mounting you laptop on the sub box will be a good idea...
    No, I don't. I guess I could make a enclosure that would mount from the rear deck, (see last pic, not my car) that the laptop would sit in, but would that make a big difference? Since the rear deck of the car also gets vibration once the subs hit.
    Here are pics of what my trunk looks like before I had subs.
    Pic of a friends car:
    FLAC ppgt94's Avatar
    May 2001
    USA
    Is that a Jetta I see? My Carputer is held down with Velcro. It STAYS PUT. That **** is strong as hell on the factory carpeting. Just use he "grab" (coarse) side.
    Feb 2004
    Quote Originally Posted by ppgt94
    Close, it's a Passat. Do you mean I should tape the bottom of my laptop the "grab" side? If so, I wouldn't want to do that since I'd never be able to take it off the laptop. Or did you mean that I should put the laptop ontop of the carpet, and take several stripes of the "grab" side and place them on-top of the laptop from side to side?
    Also, would making an enclosure, like the third pic, cause significantly less vibration to the laptop then putting the laptop right on-top of the sub-box?
    Constant Bitrate gutterslide's Avatar
    Jan 2004
    ATL
    you strap it to a board that is mounted to the sub box with some shock absorbing feet like these. i'd use the largest ones.
    or you could make a similar setup by mounting a board to the box with two sections of large rubber hose (radiator hose) separating the board from the box. then strap the laptop to the board, so it's alittle more isolated from the vibration and bumps, from the road and the subs.
    kinda like this...
    ======= <-- laptop
    --------- <-- board
    .O.......O. <-- hoses/quietfeet
    [(o) (o)] <-- sub box
    although, you might want to mount the laptop so that the hard drive is vertical to avoid damage from a hard bump.
    Feb 2004
    Quote Originally Posted by gutterslide
    I like the idea of the "shock absorbers" and maybe I could also add a thick sheet of foam between the laptop and board. Will mounting the laptop vertical and leaving it like that for a long period of time not damage the laptop?
    May 2001
    USA
    OK, scratch my idea. I just realized that if you set your notebook on the carpet it would probably sufficate its air flow. Check and see if there's a fan on the bottom of your notebook.
    Check out my favorite of all setups:
    http://pathintosh.usersites.com/Pictures010.html
    Destin's Pathintosh. He uses a Apple Powerbook.
    Might give you some ideas.
  1. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 10:52 PM
  2. would a omni ceiling mount antenna work in my trunk?
    By aoLhaTer in forum Wireless Communications
    Last Post: 07-14-2004, 02:33 AM
  3. laptop mount for car
    By trd604 in forum General Hardware Discussion
    Last Post: 03-02-2004, 12:48 PM
  4. Signal Degradation with trunk mount PC?
    By S4Per in forum LCD/Display
    Last Post: 01-20-2004, 10:04 PM
  5. Where to buy a auto laptop mount?
    By GK in forum Off Topic
    Last Post: 11-21-2003, 01:12 PM
