Results 1 to 10 of 12
Thread: Fiberglass Reshaped
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    Fiberglass Reshaped
    Hey guys... I just finished faberglassing a section of my dash, then i took it out and it looked great... although a few sections i had only got one layer of glass applied and those sections were still a little tacky, but i didnt think it was going to affect much of anything
    so i applied another layer of glass to the whole thing while it was just sitting on my garage floor, and after that layer was dry i went to make sure it still fit the dash correctly... it didnt
    i have tried to use heavy objects and tape to hold the glass back into the correct position to hopefully reshape it, but it seems that isnt going to work
    i need to know what the best way to get it back to its original shape would be... should i apply a new layer with the dash taped into its correct position, orwhat??
    any help is greatly appreciated
    Debating on installing a carpc in my Jeep.....
    Constant Bitrate coachreed's Avatar
    May 2004
    Lee's Summit, MO, USA
    You MAY be able to force it into reshaping but with this kind of stuff, your best bet is always to avoid it in the first place. When you mix a layer of resin too hot before you have a good, solid base, you risk the piece warping do to the fiberglass shrinking quickly... you may have a better chance if you go ahead and sand some of the layer(s) down that you have now... that will release some tension in that layer... and make it easier to reshape. THEN you should reinstall the piece and do as much of the fiberglass while firmly attached to the vehicle. Good luck!
    Coach... aka Randy! (I often forget who I really am!) ;)
    ***Too many pieces and parts to list... maybe someday I'll show'm to ya!***
    Jul 2004
    Tampa, FL
    ok well it should really only be one layer that is causing the problem... because the other 2 layers were fine just not strong enough by themselves to hold their position to apply a 3rd layer
    and ive narrowed the problem area down to a very small area, so i should be able to sand most of that layer off and then secure it back on the dash and reapply that layer?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    That's what I would point to as well is the heat as it is hardening. Maybe try a little less hardener so it doesn't cure so quick. And yeah, try to do as much as you can with it installed in place.
    Tidder
    Try RevFE
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    have any pics? could you drimmel with a cut off wheel to ease the tension and then put in the right place, apply resin to fill dremmel cut and then add new layer? You are going to put bondo over it as well right?
    Jul 2004
    Tampa, FL
    dremel could be a possibility... ill have pics posted tommorrow morning
    ill try using the dremel as well as sanding some off tommorrow
    also i was already using less hardener than was recommended, but the problem of the deformation was not applying enough full layers attached to the dash (my bad first time fiberglassing)
    thanks for all the help guys, and like i said ill post pics tommorrow if that will help with solutions
    Dec 2003
    not sure yet.
    did ya get it fixed?
    Jul 2004
    Tampa, FL
    well i did, but then it has reshaped again so now i just take the piece and bend it real hard in the direction it need to be bent to fix it, in hind site i shoulda put many more layers on
    Dec 2003
    not sure yet.
    what type of fiber glass clother are you using?
    Jul 2004
    Tampa, FL
    I used the cloth for that project, but i no longer use the cloth only mat
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 03:30 PM
  2. Before putting fiberglass in trunk for sub box...
    By Seabass in forum General Hardware Discussion
    Last Post: 10-08-2006, 01:30 PM
  3. Mini Fiberglass Tutorial on TLC's Rides.
    By moltensilver in forum Fabrication
    Last Post: 05-15-2006, 05:07 AM
  4. Yet another fiberglass thread
    By deligc in forum Fabrication
    Last Post: 06-27-2004, 10:36 PM
  5. Non-permanent fiberglass mount
    By Chairboy in forum General Hardware Discussion
    Last Post: 03-21-2004, 03:33 AM
