Results 11 to 20 of 28
Thread: Acura TL 2004 touchscreen install
  1. #11
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    nope, 04 is the 3rd generation....it is the first year of the redesign
    in reference to your friend's car, here is a link to our 2nd gen forum on Acura-TL.com:
    http://www.acura-tl.com/forums/forumdisplay.php?f=21
    search here, I have seen some good projects in the 2nd gen grouping.
  2. #12
    moahdib's Avatar
    Jul 2000
    Sup guys...updates are slow but forthcoming. =) I promisse to have pics as everything gets rolling as soon as i get my parts.
    I was pondering the issue of audio input. Since there are no aftermarket product that will give you aux input for this car ( unless you want to lose XM) there are 2 solutions that can be easily implemented.
    1- Tap into the XM unit using a 4PDT relay ( 4 relay contacts ) for L+ L- and R+ and R-. All you need then is to power on the relay by a switch to go from XM to PC audio.
    Cost is like $12 for a 4pdt relay or you can use 2 DPDT relays.
    2- Tap into the audio going into the amplifier if you have a 5.1 sound card. Then you will be bypassing all radio control functions ( volume mostly) which you can just use PC to control anyway. This would require 9 wires to be connected. Amplifier inputs from the radio are 3 wires (Left+, Right+, common) for Front and 3 more for Rear speakers. And 3 wires for Subwoofer and Center ( + Center, + Subwoofer, common).
    This would need two 4PDT relays and 1 SPDT relay all connected together and a switch button of course to toggle between radio and PC input.
    Sounds kind of crazy to use that many relays but I don't see another way of doing this. Right now I will go for tapping into the XM unit and see how that works and keep everyone updated.
    Now the HVAC LCD fits very nicely on the lower compartment. I bough a piece of smoked plexiglass to cut to shape and cover the front. Just to make it look more stock I got a piece of carbon fiber vinyl (sticker type) to put on top of it and cut the rectangles for the display.
    I just made a switch box with the buttons to control the xenarc and the switches for audio and disabling the power to the PC ( whenever I valet my car, etc...).
    This weekened i'll probably take a look at how I will be wiring everything to the trunk.
    Any of you guys looked into this yet?
    On a side note... I also bought this:
    http://www.dealtime.com/xPF-Griffin_...rMate_1040_PMT
    Which just looks AWESOME and not to say that it has a blue light to match the interior of the TL perfectly. It looks EXACLY like the big knobs on the factory radio! I'll figure out a place for it when its all done.
    Sorry for the long post =)
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  3. #13
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    The powermate will fit in perfectly with you radio, lucky, I will pretty stock. But I've heard it has some problems running under windows, thats why I haven't purchased one, plus its to big for my car interior and it doesn't match.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  4. #14
    moahdib's Avatar
    Jul 2000
    I am also getting some help in interfacing the steering wheel buttons to work with the joystick port on the PC on this thread here...
    http://www.mp3car.com/vbulletin/show...749#post282749
    Hopefully these diagrams will be worth the time i spent making it. LOL
    and
    My TL CarPC ver2
  5. #15
    moahdib's Avatar
    Jul 2000
    Here's a sneak peek =)
    My TL CarPC ver2
  6. #16
    Low Bitrate bLindmOnkey's Avatar
    Jan 2004
    sdale
    looks great . Now if only I had a tl2004...
  7. #17
    Oct 2003
    DC/VA
    great work man! Always nice to see new custom installs that come out awesome.
  8. #18
    moahdib's Avatar
    Jul 2000
    Thanks guys..
    I'd say im about 90% done. Well i am now in the process of wiring the 5.1 audio with 2 or 3 4PDT relays... hope the sound will come out cleaner since its out of a usb.
    My TL CarPC ver2
  9. #19
    Low Bitrate modUlarBeing's Avatar
    Aug 2004
    oooooh i wanted a tl soooooo bad.....couldnt afford the new one so i got the rsx hehe
  10. #20
    Nov 2004
    Cool that looks good!!!
    I own a 04 TL and want to do the same thing. If you could tell me where you bought:
    1)connectors to extend the wire from the stock lcd
    2) smoked plexiglass and that carbon vinyl
    how did you make the smoked plexiglass attach to the storage bin in front o the lcd? any help will be appreciated.
  1. Weird 04' Acura TL Alpine OEM Nav video feed?
    By EggrollXpress61 in forum Newbie
    Last Post: 01-27-2007, 09:11 PM
  2. Replies: 5
    Last Post: 01-30-2006, 06:26 PM
  3. Acura OEM touchscreen?! ANYONE KNOW?!
    By EggrollXpress61 in forum LCD/Display
    Last Post: 07-24-2004, 02:13 PM
  4. Acura TL 2004 LCD
    By TLer in forum Car Audio
    Last Post: 07-06-2004, 02:00 PM
  5. Install in a 99 Acura TL
    By codelogic in forum Show off your project
    Last Post: 04-12-2004, 04:39 PM
