Results 1 to 10 of 17
Thread: The Fabrication Has Started On My Zpc
    Aug 2004
    Mississippi USA
    Ok I started my new carpc or in this case a ZPC. This is my car the car I'm putting it in to put it in.
    This is where the idea for my enclosure came from.
    http://upload.nowherenews.com/img/1344DSC01596.jpg
    This guy made a huge speaker enclosure. Mine is going to only occupy the space under the rear strut tower brace. The other thing I plan on is a big Z sign on the front of the box which is going to be a window looking in at all the components. The inside will be painted white with a black light to illuminate the interior.
    Now the first thing is how I mount the desktop MB in a wood box. So I took the whole computer case apart till I was left with just the metal plate that the MB was attached to and as you can see in this bad illustration. Then I folded it so it would hold the MB at the angle I needed it to be at.
    As for the the HD and CDROM I used the cage from the case to hold and mount those. Unfortunately I’ll have to re do this because it’s a little off.
    The last thing I have to do is construct a way to hold the PCI and AGP cards in place so they don’t flop around.
    Here are 2 more pics of the whole thing with the front in place. Not to much room in there
    Considering this is the first fabrication job I have ever done please post comments and sugjestions on where to go from here.
    2003 Nissan 350Z Touring
    CarPC in the works Now Its done
    Aug 2004
    Mississippi USA
    Oh one other thing is all the dvd functions will not be done by the cdrom in the case I will be mounting another dvd drive in another locatin in the car.
    Newbie Elderm007's Avatar
    Jun 2004
    Michigan
    you might want to mount you HDD Vertical. but other then that nice work
    Jan 2004
    St. Louis
    The size and weight of that heat sync and fan might cause problems with the sideways mount. Vibration might knock it loose from the chip because of it's weight. Looks good though and great attention to detail. I like it when folks plan and put detail into their projects.
    Aug 2004
    Mississippi USA
    OK So HDD vertical and the heat sink is to big.
    That heat sink is actualy smaller than the other one I have for my another P4. If I find one that is smaller you don't think there might be a heat problem?
    Thanks Its been in the planning for a wile.
    Constant Bitrate leemik's Avatar
    Aug 2004
    MA
    Hey man looks good so far..
    Did you see my ZPC
    I didn't ending up building a box, I just stuffed everything into one of the small "mailslot" compartments behind the passenger seat.
    What kind of power supply are you going to be using?
    Judging from your license plate frame, I think you are local to me too..
    --mike
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Looks similar to a system I built for a Z. Nice work how are you planning to finish the enclosure?
    Fabricator
    Aug 2004
    Mississippi USA
    That is sweet.
    Yes you live in MA I live in RI. I work on the cape.
    God I wish I had your cash dude, hell I havent even bought the screen yet. All the parts you see I had lying around my house.
    Aug 2004
    Mississippi USA
    altimat I was probibly going to do carpet. I don't have your skills man
    Oct 2003
    WI
    Quote Originally Posted by zmann
    Sure looks like you do to me. I may have more experience, but this stuff isn't rocket science, you just do it and learn as you go. You're doing a great job keep it up!
    And I wouldn't worry about the heat sink falling off that seems unlikely.
    Fabricator
  1. Warning... crazies ahead.
    By ddt in forum Off Topic
    Last Post: 05-12-2004, 12:06 AM
  2. I just started my website can...
    By churnopol in forum Off Topic
    Last Post: 11-14-2003, 09:26 AM
  3. iWill ZPC?
    By iulery in forum General Hardware Discussion
    Last Post: 09-26-2003, 01:27 AM
  4. Getting started
    By Xanxes in forum General Hardware Discussion
    Last Post: 02-18-2003, 12:39 AM
  5. 1992 Maxima (just started, well ... just started progress)
    By arsalan_altaf in forum Show off your project
    Last Post: 10-18-2002, 03:55 PM
