Results 1 to 7 of 7
Thread: Adding On to Length Of Fiberglass
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    Ok So I Have A Fiberglass Piece That I Made And Has Already Cut Off The Excess.... But In My Haste Cut Too Much Excess Off And Need To Add On To Make It Longer, What Is The Best Way To Add Fiberglass To A Piece To Make It Longer?
    Debating on installing a carpc in my Jeep.....
    Jun 2004
    Why didnt you capitalize the "to" in the title?
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    how does it sit on or what does it sit on. On the back side of your fiber glass does it have to be flush with something? Could you fiber glass the back to the length you need it. Then from the end of the front add on the laters to match.
    Edit: like this kinda?
    Jul 2004
    Tampa, FL
    I'll have pics of it up in a few minutes... But it is a case for a pc, and the edge needs to meet with a piece of plastic... kinda hard to explain so ill post a pic of what it is now and then shade in what needs to be added on
    Jul 2004
    Tampa, FL
    Images Of Case... Gray = Needed Addon
    Dec 2003
    not sure yet.
    Im not sure what it is for. try what i said before and perhaps some mat on the the top as well. Or myabe just some on top and bottom. Im no pro only done fiberglass a few times.
    Jul 2004
    Tampa, FL
    it is an anclosure for my pc, in a cubbyhole in my trunk, so i just need the fiberglass to fit snug... ill try it out though, thanks
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 03:30 PM
  2. Mini Fiberglass Tutorial on TLC's Rides.
    By moltensilver in forum Fabrication
    Last Post: 05-15-2006, 05:07 AM
  3. Custom length IDE cable (HD, CD/DVD, Floppy)
    By jtk in forum Classified Archive
    Last Post: 03-23-2005, 03:45 PM
  4. Lillput- Fussy about VGA cable length?
    By live2themaxuk in forum LCD/Display
    Last Post: 08-22-2004, 08:03 AM
  5. Non-permanent fiberglass mount
    By Chairboy in forum General Hardware Discussion
    Last Post: 03-21-2004, 03:33 AM
