Results 1 to 10 of 13
Thread: Quick Help!
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Quick Help!
    Hey all, I got a quick question. I've got an 04' tacoma and I'm fully integrating the touch screen into the dash. I went out and baught a seperate radio bezel so I can cut it up.
    I've been reading all the articles on how to bondo/fiberglass the screen and I think I'm confident with that, my question is this:
    What should I use to cut the plastic around the bezel ? I was thinking a hand Dremel, but the plastic is pretty thick any sugestions would be great thanks guys !
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I think you would be able to use a dremel to cut through the plastic easily. I myself uses a blade from a hand saw and cut mine manually, but the plastic on my casing was not too thick. Oh, and with the dremel you will have to me careful with burning the plastic, I've burned wood with that thing.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    I used a simple cutoff wheel.... just a bit that goes on to your drill and you put a cutoff wheel on it.... you'll go through a lot of them but it gets the job done well.. you can see how mine came out in my Project CompuMach thread
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    dremel and quattro is right dremel will melt plastic so watch out for that.
    Mine needs to be updated.
    Elsewhere
    Quote Originally Posted by samc
    Dremels have adjustable speed. Slow it down when cutting plastic. It will help prevent burning, as well as make the cutting wheels last longer.
    How about the Wiki?
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    Dremel is a neccesity in life.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Denmark
    a Jig saw is just as good... and much easier in my opinoin.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Dremel = knife through butter. I'd suggest trying it on a CD jewel case or a floppy and try to cut a straight line without melting it. Take the CD out first, though.
    Jun 2004
    NH
    Quick Help
    Thanks for the input guys, I'm probably going to have to go out and buy a dremel, but it seems to be the way to go.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Constant Bitrate mindscream's Avatar
    Jun 2004
    Memphis
    All this talk about Dremel is making wonder if my Dremel is feeling lonely, there...at home... all by itself...
    I think I'll go buy a new attachment for it today and make it feel better
    As for the plastic... I just got through using my Dremel to convert a 30" aquarium hood to a 24" <evil grin> I had a lot of fun with that project <g>
    The plastic melted, flew and there was a smell in the air... I love the smell of burning plastic in the afternoon... smeels like... testosterone
    Mind Scream out
  1. Quick release components
    By chuckster in forum General Hardware Discussion
    Last Post: 10-06-2004, 10:52 AM
  2. Starvision LCD.....quick question.
    By Seabass in forum General Hardware Discussion
    Last Post: 05-27-2004, 07:38 PM
  3. opus and inverter quick q
    By sweetrobot2k in forum Power Supplies
    Last Post: 10-16-2003, 01:03 PM
  4. need win 98 SE quick!!!
    By cubanmoses in forum General Hardware Discussion
    Last Post: 08-10-2003, 08:47 PM
  5. 10.5" LCD Panel - Get it on Ebay Quick
    By kmfdmk in forum LCD/Display
    Last Post: 03-05-2003, 10:26 PM
