Results 21 to 30 of 34
Thread: How can I make my install look better?
  1. #21
    Aug 2004
    dont use bondo it breaks off. Fiberglassing is a little messy and harder to work with but it also has good results.
    You can also use MEK(methyl ethyl kektone) Itss a solvent you can find at most hardware stores. Get some old ABS plastics laying around and drill holes in it or find a way to make shavings from it. Collect the shavings. Put them in a small non-plastic container and add a little MEK. Dont put tooo much. This will make a plastic putty. Now you can use it to fill and mend the holes and gaps. You can sand and paint it once it hardens.
    MEK is powerfull stuff so its better to use a little then too much.
    MEK can be harmful so make sure you have some good ventilation.
  2. #22
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Tbird- Fixed your bezel for you...
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
  3. #23
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Now that's what I want!!! If it were only that easy...
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  4. #24
    Oct 2003
    Poland, OH
    Quote Originally Posted by sesshoumaru562
    Well the stuff I already purchased is All-Purpose Fiberglass Resin and a Fiberglass Cloth.. Are you saying not to use this now?
  5. #25
    Aug 2004
    I was saying not to use bondo. Bondo is really weak. Fibger glass will work fine.
  6. #26
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    reply.
    Tbird, I'm actually doing this today as well. just finished cutting the radiobexel and I'm fitting the screen as we speak.. gonna bondo it later today (my dremel battery died with only a few cuts left)
    I baught: Bondo-Hair Fiber Glass 25.oz (for the major bondo-ing) then I baught a tube of Glazing and spot putty BONDO. All this @ Autozone.
    Good luck !
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  7. #27
    Constant Bitrate CustomZ02's Avatar
    Austin, TX
    I used Bondo-Glass first. Then Filled in with bondo. If you use the sheets I believe its harder to work with on a small project like this. Ill show u some more pics here.
    What I did was I used the front panel of the Lilliput Set it where I wanted it after I did some cutting. Then with some Bondo-Glass I put it around and on the frame to hold it in place. After letting it dry for about 10mins or so I sanded it down a bit.
    Starting new project. After some jackass broke in and stole my screen.
  8. #28
    Austin, TX
    Then fill in with just the regular bondo-body filler type. And sand down to a smooth surface. You may need to keep apply small amounts to fill in small gaps or un even spots. Mine took me 4hrs but heres a pic with the bondo.
  9. #29
    Austin, TX
    Tbird what I did was remove the front of the lilliput and mounted it on the front side of the bezel. Then bondo'd to fill in the sides and make it look like one piece. Then fromt he back I mounted the lcd and screwed in the back part of the lilliput so its like one piece again.
  10. #30
    Oct 2003
    Poland, OH
    Ok.. I took my bezel and LCD out to give everyone a better idea so you can hopefully give me a better idea...
    How it is currently:
    Bezel by itself... As you can see I really murdered it...
    Without the plexi holding it's depth:
    Hopefully with the pictures this will give everyone a better idea to help me out.. Should I remove the front cover of the Lilli and mount it as flush to the back of the bezel as possible? Is this still doable with all the hacks I made to the bezel?
    Thanks again!
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. My Install in A Lexus IS200 UK Spec
    By Brettster in forum Show off your project
    Last Post: 04-30-2007, 09:20 AM
  3. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  4. Lilliput 619GL-70NP Touchkit XP Home Install
    By Windchsr in forum LCD/Display
    Last Post: 04-25-2004, 08:23 AM
  5. Those running Linux from CF, how to make bootable?
    By eugenen in forum Software & Software Development
    Last Post: 11-10-2003, 01:18 AM
