Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: How can I make my install look better?
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Here is my screen job... I'd like to make it look more factory but don't know where to begin or how much work it would be...
    If someone could just throw out a few tips I'd greatly appreciate it..
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Constant Bitrate dexy's Avatar
    Jul 2004
    NY
    I would suggest getting some bondo (from autozone/home depot), and flush fill the sides of the lilliput to stream together with the dash. The bottom where it meets your AC controls, I'm not sure(you gatta do some artwork there), You can use bondo to make them look joint together.
    Also realize that when you do this the front of the lilliput is fixed to the panel. So you would have to take the front cover off the screen, and remove the panel itself to do this work. When you are done, join in the other half of the lilliput from the back of the panel. The sticky in the fabrication thread shows how to do this. You do not need the foam(in his example).
    In a barn
    ya bondo. fiberglass... lots of sandpaper... and time
    When in doubt, moo at things.
    Constant Bitrate snmnetwork's Avatar
    Aug 2004
    Atlanta, Ga
    Cut the bottom of the lilli off! The whole button panel must go. Relocate the button panel behind the lilli and relocate the ir receiver. Unsolder the IR receiver from the panel and use wire to connect it back to the panel. That way you can put the IR receiver any where you like. Mold it in the dash or simply put it behind the vents. Kitty hair/bondo the bottonm to mold it in, and bondo the sides.
    Status: [|||||||||-] 90% finished
    My 2000 Chevy Monte Carlo SS Install
    Aug 2004
    Atlanta, Ga
    Aug 2004
    Atlanta, Ga
    forgive me i'm bored
    forgive me i'm bored...lol
    Jul 2004
    that photoshop gives you a good idea of what to shoot for, but I liked your install anyways...just needs some finishing touches
    Jul 2004
    Memphis, tn
    I have the same problem with the future insall of a lilliput into my Yellow Ranger Edge. I was thinking that maybe i would cut some of the bezel under the AC vents and move it up a little bit. The biggest problem is how to access the lilliput after bondo. The bezel is 3 ish inches deep. Guess you could really murder the thing and disect it. Most of us Ranger people have a few of the bezels laying around.
    Jul 2004
    Memphis, tn
    If you haven't already, you could probably remove the screw holes behind the lilliput buttons. I think the bezel should hold in there on its own. this would allow you to bond the whole bottom in. I myself am trying to decide on whether to put the computer in the dash where the 2 din cd player goes, or to do what you did and install it in an explorer console. If i can find one of those at the junk yard.
    Oct 2003
    Poland, OH
    Thanks for all the ideas everyone... Snmnetwork.. Thanks for the pictures.. That definately helps for a visual. I'm a little hesitant with taking apart my Lilli. All the threads of people having problems and mine works 100%. I would be afraid to jack it all up..
    How touchy is it? That photoshop looks sweet w/ your makeshift bondo
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. My Install in A Lexus IS200 UK Spec
    By Brettster in forum Show off your project
    Last Post: 04-30-2007, 09:20 AM
  3. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  4. Lilliput 619GL-70NP Touchkit XP Home Install
    By Windchsr in forum LCD/Display
    Last Post: 04-25-2004, 08:23 AM
  5. Those running Linux from CF, how to make bootable?
    By eugenen in forum Software & Software Development
    Last Post: 11-10-2003, 01:18 AM
