As stock as it can get. Super nice job man. Congratilations!
Well after a week of P38 and elastic fillering ing eg fiberglassing and 'bondo-ing Ive finally managed to get a result im happy to show off.
This is a Gain 700TSV molded into the double din of a 2001 VW Polo GTI. Managed to match the dash paint very well but as its not in the car yet its hard to demonstrate this.
I started off ny demeling out the hole so the front part of the screen would fit itn the hole. Then i fiberglassed (P40)around the edge and from the back to give it support around the edge. Then i sanded it slightly and the started filling with some elastic filler and sanded etc etc from there. I hope the elastic filler 'give' abit more with the sun etc etc and will not split like bondo or P38 can. The when i thought i had a decent shape i sanded the whole thing down and plastic primered the top area of plastic as the whole thing had to be resprayed, the just grey primered the whole lot. Saw some imperfections so fillered small areas and holes and primered again to work until i was happy. WHen i was i primered the whole thing again P1200 sanded it all and began the top coat. I used some Holts acrylic gloss black held back about 30" away from it and did loads of light coats to built up to this textured look.
Had a few probs en-route. Was hard to get the edges of the screen rounded and looking nice but a few primers and sand sessions later it looks OK. Also the buttons initially at the primer stage didnt fit properly as the filler and printer had made the holes just a tiny bit too small but again minor issue sorted now. Luckliy NO HAIRS at the painting stage, happy days. Only 2 on the final light coat which i just puled off when dry with no probs as it was such a light coat. WHen i was putting it together i was crappin myself the connector at the back woulnt fit but i managed to remove the plastic surround which gave JUST enough room for it to fit. Even detailed the little symbols near the ventshappy days
Lemme know what ya think
Verrrry niiiiice! Bondo?
Excellent job, looks really good. What type of paint did you use?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
that is off the chain, how on earth did you repaint the whole thing without spraying over the white numbers near the ac vent dial?
Mine needs to be updated.
Well it wasnt bondo if was this stuff in the UK made by Plastic padding called Elastic filler. The fiberglass was the matt is resin stuff called P40.
I repainted the whole thing, painted over the vent symbols then repainted them with white touchup and a steady hand.![]()
very very very nice!!!! The next time you visit the states let me know I will let you work on my Durango or Jetta any day!
[COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
Very nice indeed
Like to see the work in stages though.
EXCELLENT WORK! Post some pics of it installed.
excellent work!
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
